Drawbar help
/ Drawbar help #11
I guess moving 1 trailer that would be fine. When i am moving trailers it's typically 5 or 6 of them in my back lot so the 3 point ball is ideal as the 3 point lifts them and i don't have to mess with the jacks. I just welded it up out of scrap and slide my hitch into the receiver.......
You seemed to have misunderstood the original question.
/ Drawbar help #13
/ Drawbar help
Never saw this before. Anyone have experience with it? Wouldn't mind trying it around the barn but what about highway use? Can it be trusted?
I think if you stick to the weight ratings you should be fine. For my truck I use a 3 way hitch which has a much higher rating.
/ Drawbar help #15
I’ve never had one myself, but know people who use them all the time. I’ve personally never heard of a problem occurring.
/ Drawbar help #16
I have the exact same interchangeable ball set. I've used it for many years around the property and have towed up to 11,000 pounds with the tractor, which is 3K over the rated limit for the ball with no problems. I have never used it on a truck and if I did I would never go beyond the 8000 pound rated limit. If it's rated for highway use up to 8000 pounds I'm sure it's fine for that.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A60736)
2005 DRAGON 130...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
Bobcat T590 (A53317)
2023 GMC 1500 Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC 1500...
