Drawbar for M7040
/ Drawbar for M7040
Get the proper drawbar.
No you don't want it to swing.
No you don't want to use a 3pt cross bar with PTO pull type. You are asking for your PTO shaft to get bent or broken
That was my original thought on this.
/ Drawbar for M7040 #12
It will be best to use a draw bar due to the pto shaft. If you or someone else forgot and accidentally raise the arms on the drawbar your going to have some bad issues.
……, and there is also a specific measurement from the d/b to the PTO, this will be much too long using a 3 pt. d/b.
/ Drawbar for M7040 #13
So.... here is a pic of the OEM drawbar off my 2009 M6040. Kubota says the drawbars on the M5040, M6040 & M7040 are all the same.View attachment 478221
Now for some measurement data--
the bar dimensions - 24 1/8" OAL, 2.5" width, 1.25" thick
Starting with the largest hole(implement pin attachment hole) on the far left
First hole - 1 3/8" diameter - 1.5" from end of bar to center of hole
Second hole - 3/4" diameter - 7 3/4" from end of bar to center of hole
Third hole - 3/4" diameter - 9 3/4" from end of bar to center of hole
Forth hole - 1" diameter - 20 7/8" from end of bar to center of hole
Fifth hole - 1" diameter - 22 3/4" from end of bar to center of hole
The first large hole is for attaching the implement to the dawbar, hole #2 & #3 are just random attachment points and #4 & #5 are alternate locations for attaching the drawbar to the tractor.
I don't keep the DB attached - it sticks out far enough to interfere with some of the 3-point attachments.
It would seem that the width, thickness and drawbar attachment hole(s) diameter would be somewhat critical. The length and remaining three holes would be specific as to how you intend to use the drawbar.
Boy I tell ya, you answered my exact question. I am looking for a shackle for my M7060HD12 drawbar and you nailed it. I have the tractor on our 2500 ac lease and forgot to measure the hole in the draw bar before I left. The first time I hauled it, I used a hitch ball to hold the tie down chains because I didn't have a shackle the correct size. Thanks for taking the time to measure so completely.
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
2013 NISSAN NV3500 CARGO VAN (A59906)
2013 NISSAN NV3500...
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
