Draw bar
   / Draw bar #1
BBB
Bronze Member
I have just started using my draw bar to move trailers. The bar works well, but is there a device that prevents the bar from rotating? I am using a quick-hitch from HF so the device needs to work with that also.
   / Draw bar #2
   / Draw bar
Ordered one!
Don't think it will work directly with the quick hitch. but with a slight modification I think I can make it work.
Barry
   / Draw bar #4
I use this:
http://www.tractorbynet.com/forums/attachments/39077-ezmover-hitch-system-intro-special.html
I don't use a quick hitch. I do use Pat's Quick Hitch:
http://www.tractorbynet.com/forums/attachments/31818-pats-easy-change-system-order.html
The ExMover is great - heavy duty and allows you to use any 2" x 2" bar and hitch combo. Great for moving the travel triler around. I can take out that bar and put the one with a small ball on it for a utility trailer, etc.
Pat's is not a complete answer. But, it helps a lot. On and off the tractor once, instead of several times. Generally I am pleased with it, but do question the angles involved.
Using the above combo allows me to pick up and use nearly anything - easily.
2014 Freightliner M2 106 Medium Duty Truck, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
2012 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A52141)
2012 VOLVO VNL...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
Kubota SVL95-2s (A50120)
Kubota SVL95-2s...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
