Draw bar mount a rear differential Cover?!?!?Help!
   / Draw bar mount a rear differential Cover?!?!?Help! #1
jdmar
Ohio
JD 5425 & 4300, Yanmar 1500
OK, so I was about to remove my drag/draw bar with its welded plate on my YM1500 2WD....then...
I loosened the 8 bolts on the under side to remove the mounting plate so I could weld a more custom (one that works better for me at least) draw bar. Then I started to get a bit of a leak of what sure looked like tranny fluid to me! Call me stupid (then again just help me!) but I would have thought this was removable without opening the underside of the rear-end. It was no big deal...I just retightened and the leak is done. If I need to I can always totally remove it then reseal it.
But it seemed strange that the structural mounting for the draw bar was also a bottom access plate of some sort to the rear end. On my tractor there is a plate about 6x10" and 5/8" thick. This plate bolts under the rear end. The draw bar is welded to this plate. If have attached a pic to try to make my question clearer.
Is there a large hole under this plate to allow access/inspection to the rearend? Or do just the mounting bolt holes go into the rear-end. I know I could answer my own question by removing it...but I'd figure I'd ask the pros first and learn something.
Thanks for the help
Peter
   / Draw bar mount a rear differential Cover?!?!?Help! #2
I don't know the answer, but isn't the fluid going to fall out in either case if you remove the plate?
   / Draw bar mount a rear differential Cover?!?!?Help! #3
There is a hole large enough to get your hand in to remove the bolt that holds the bull gear on the end of the axle.
Danny
Parker Equipment Co
Thanks for the info, Danny. And thanks for sending me the parts in the mail (filters, exhaust gaskets, hood rubber trim). Your "check is in the mail" for payment back to you...really it is!
Peter
2023 FORD F750 CAB & CHASSIS (A53426)
2023 FORD F750 CAB...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
