Draining the 4510 radiator
   / Draining the 4510 radiator #1
yanmars
Veteran Member
I admit I just took a quick look but I did not see a drain petcock on the radiator of the 4510. Where might it be or do you just loosen the lower radiator hose? My Yanmar has a block water jacket drain.
Ideas/suggestions. Thanks
   / Draining the 4510 radiator #2
Check 6 inches behind the oil filter. There should be a wiite plug. I think it will drain the block to. How do you like your 4510?
I had a few reservations at first as I was used to an open or non-cab tractor. I like it now as it has more horsepower than my Yanmar 336d.
The thing I dislike is the cooling system. It gets debris on the radiator, the screen looks difficult to remove, the battery and air filter block a great deal of airflow into the radiator etc. That system could have been better designed IMHO.
   / Draining the 4510 radiator #4
I had my screen out a while back. A few bolts and it kind of slid sideways a little as I remember. I seldom use the bushog so mine dosen't get plugged bad. I've had good luck with it till recently. I went to road it a couple of miles and it started to blow gray smoke and miss bad. It doesn't do this till you get it up to pto speed and put a load on it which I don't do very often. Mine has 700 hours on it. Guess I'll have to haul it the hundred miles to the dealer while its under warranty. I've really liked it though. I mostly us it for the loader.
2016 Chrysler 200 Limited Sedan (A48082)
2016 Chrysler 200...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
UNUSED 30PCS Eye Lifting Hooks w/ Crane Hoist (A50860)
UNUSED 30PCS Eye...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
