Draining old fluid from used implement
/ Draining old fluid from used implement #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
My "new" snowblower was of course a used snowblower. My hydraulic sump is 12 gallons, but I still did not want to mix the unknown "foreign" oil from the hydraulic chute pump into my common sump. I came up with a solution.
I hooked up one hydraulic line to one of the two toplink lines, then "purged" the system. I operated the toplink until clear, clean fluid passed from my sump into the chute pump, and out the free unattached hydraulic line. After a few squirts, pump and lines purged of all old fluid. Then I connected the free line and the chute worked fine. The result was not having any old unknown oil in my sump. Probably not a big deal, but TBN has encouraged me to sweat the details.
Bob
/ Draining old fluid from used implement #2
Good job, I would have done the same. For that reason I refuse to rent hydraulic implements, (like a Harley rake), I don't want unknown hydro fluid running through my machine.
Thanks. I was told by some not to worry. They are probably right that the amount was miniscule. But, I figured out a way to drain the fluid and avoid all questions about how much contamination with the wrong oil was tolerable. And since I own it now, no further need to drain fluid. Also, helped clean any other "stuff" that might have been in the lines.
Bob
/ Draining old fluid from used implement #4
Guess I should consider this when i go to hook up that overgrown cylinder I dragged home the other day...
Thanks,
David from jax
/ Draining old fluid from used implement #5
Bob
Isn't that the truth! I never cared so much for my other equipment as when I joined TBN. Some tractors need more TLC than others. But it is a good thing and has carried over to other stuff. Now, I regularly rotate the lug nuts on my golf cart.:confused:
Okay, I will bite, why ?
Bob
/ Draining old fluid from used implement #7
Bob
Bob just a guess but I would say 3RRL is pulling your leg a bit on the lug nuts....
/ Draining old fluid from used implement #8
Bob
Bob,
I think you did the right thing. After all, you were able to tell when your tractor's clean oil came out, so the implement must have had unclean oil in it. What was it contaminated with? Were there metal shavings or chips in it? Water? Dirt? Was it overheated and broken down? Was the viscosity the same as your tractor needs? The point is, you don't know~! For the very small amount of time you spent on it, how can you go wrong?
jb
john_bud said:
Bob,
jb
Opaque and white (water??)
Bob
/ Draining old fluid from used implement #10
Yep, that would be water. You definitely did the right thing two ways. Water in the blower could freeze and not be operable when you need it and water in your transmission can do some real nasty things. Rusting the sensitive hydraulic controls inside as well as the clutches.
The question is where did the water originate? Leak into the previous owners tractor or into the snow blower? You may want to keep an eye on the quality of the fluid in your tractor as you use the blower. Check the various seals on the unit to see if any are leaking.
jb
jb
I am guessing, from the previous machine. So far ano leaks anywhere on the blower. I only used it for an hour, but it worked fine. I needed more than 12 inches of heavy wet snow to really test it :D
Bob
/ Draining old fluid from used implement #12
Doc,
Mike is right and I apologize for pulling your leg a little there.:)
Not to detract from your thread at all ... you have certainly done the right thing in changing the fluid and looking into further maintenance. All good things. I was reflecting in the suttle wisdom of your statement and how true it really is Probably not a big deal, but TBN has encouraged me to sweat the details.
I have found myself paying attention to detail in an **** sort of way and that was a humorous attempt at describing it. Like I said, it's a good thing and certainly better than the alternative.
Regards,
3RRL said:
Doc,
No problem. Enjoy the conversation.
Bob
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
Mower King ECSSTR072 (A64127)
Mower King...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
Winchester Sign (A64127)
Winchester Sign...
