Tires draining fluid from tires
   / draining fluid from tires #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
I'll be hauling a tractor, TO-20, a 1000 mi soon. I desided to drain the fuid from the rear tires to reduce weight. Any tricks?
I planned to remove the fill tube center and leter drain. now that will leve some but, close enough.
Patrick
   / draining fluid from tires #2
Reach around from the front or rear of the wheel. Don't stand in front of the valve! You have the rest figured out.
I thought I might do it my heated garage. So I was thinking of using the filler tube a "fix-a-flat". The end has the screw/center point. Then run the tube to buckets. By leaving the center part of the fill valve in place, I could stop every so often to run up the presure with air.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
TRUCKING INFO (A50774)
CURTIS ELECTRIC AIR COMPRESSOR (A51244)
CURTIS ELECTRIC...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
2021 SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
2021 SELLICK...
