drain plug washers
   / drain plug washers #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
my tractor has 2 sizes of drain plugs. 12mm and 16mm. The factory seals are rubber/metal. dealer prices are nuts. I looked for Dorman equivalents but at the time I could only find fiber ones. What the heck I put them in. Now I worry. The engine will get changed again next fall, I since found Dorman 12mm rubber/metal.
The 16mm I only found copper. Should have used that. Transmission with 16mm plugs , Will see how fiber stands up for 300 hrs , be a while unless it starts leaking.
Anybody use fiber washers?
   / drain plug washers #2
Just keep an eye on them you should be fine , You could always change them pull the plug and put your finger over the hole and with the other hands clean the plug install the new gasket washer....:)
   / drain plug washers #3
As a rule I don't replace drain plug washers every time I change oil. Once they get mangled to the point where they leak a few drips...then they get replaced. I usually have the main ones I use in stock. Like if I go and put all the effort into finding a supply I buy more than one so that the next time I need a washer I have it.
Copper washers work just as well as the rubber washers. The fiber washers you used will be ok also.
   / drain plug washers #5
For 30+ years I've used copper or aluminum, changed at every fluid change.
   / drain plug washers #6
Check with your local hydraulic shop, I was getting a hose made recently and found they had all different sizes of high pressure seals made exactly like the metal/rubber drain gaskets. Cost was about $.80 as best as I remember.
   / drain plug washers #7
I was stuck once when changing out my oil.
I made some 'crush washers' from HD poly sheet that I had on hand.
Worked out just fine and never leaked at all.
Fact is oil never gets all that hot otherwise I'd of had a leakage.
LOL, I now have a KIT of crush washers that I purchased on line.
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
RoadTec RX500 Screener (A53421)
RoadTec RX500...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
New Holland B95 Backhoe (A50490)
New Holland B95...
