Drain First?? When cleaning the transmission fil.
   / Drain First?? When cleaning the transmission fil. #1
mrtractortire
North Carolina
Yanmar 1110d
Can you clean the transmission fluid filter on a yanmar w/o draining the fluid, or is the fluid level above the line, and if you take it off to get to the filter, will fluid go everywhere? I just want to check the filter for trash and see if the fluid needs changing.
thanks,
tractor
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
1964 Mercedes (A51694)
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
