Drag Tips for Plasma cutters
   / Drag Tips for Plasma cutters #1
Haywire
Central Kentucky
Tractorless :(
Anyone use a tip like this? Looks like it has built in spacers to hold the tip off the surface.
Ian
   / Drag Tips for Plasma cutters #2
That looks like a good price, why dont you try some and let us know!!!:thumbsup:
   / Drag Tips for Plasma cutters #3
Ian
I saw those tips and electrodes on the Northern Tool 325 40 amp plasma cutter. There is a gas distributor that goes with that set. I see it's not listed.
   / Drag Tips for Plasma cutters #4
I have used both drag tips and the 'regular' kind. Drag tips are nice when you are using a straight edge or pattern to guide the cut. You just have to concentrate on moving at the right speed and you get beautiful cuts. Since you can't see the penetration point they are not that useful for free hand work where you are trying to follow a line etc. by eye. Also useful when cutting up scrap where you don't really care precisely where the cut is made. I keep both kinds around and change to suit the kind of cut I am making.
Thanks, I think I'll spend my money on a roller guide instead.
Ian
   / Drag Tips for Plasma cutters #6
I really need to get a hand torch option for my plasma cutter.... i keep meaning to then i see the $600 price tag and forget about it.
there sure are times that i could use it instead of hauling out the OA setup.:mad:
Sounds like he has a machine torch for a CNC table. Don't know how many amps your plasma has, but this is the one on my 50a and it's less than $100, you'll just have to adapt the connections to your machine.
edit 80-100a, 25' cable, similar price
Edit 2... might be import duties on those. Also, the first torch isn't set up for HF, not sure about the second.
   / Drag Tips for Plasma cutters #9
I used to work in a fab shop we used drag tips all the time with a straight edge or homeade pattern all the time. a framing square works nice as a straight edge clamp it to the metal with a couple of vice grips. we would lau out the cut line with soapstone and then lay a line where to set the guide.
JG, how thick was the metal you were cutting?
Ian
UNSUED WOLVERINE TL-12-72W-72" HYD TILLER (A51248)
UNSUED WOLVERINE...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
