Drag Tips for Plasma cutters
   / Drag Tips for Plasma cutters #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
Anyone use a tip like this? Looks like it has built in spacers to hold the tip off the surface.
Ian
   / Drag Tips for Plasma cutters #2
That looks like a good price, why dont you try some and let us know!!!:thumbsup:
   / Drag Tips for Plasma cutters #3
Ian
I saw those tips and electrodes on the Northern Tool 325 40 amp plasma cutter. There is a gas distributor that goes with that set. I see it's not listed.
   / Drag Tips for Plasma cutters #4
I have used both drag tips and the 'regular' kind. Drag tips are nice when you are using a straight edge or pattern to guide the cut. You just have to concentrate on moving at the right speed and you get beautiful cuts. Since you can't see the penetration point they are not that useful for free hand work where you are trying to follow a line etc. by eye. Also useful when cutting up scrap where you don't really care precisely where the cut is made. I keep both kinds around and change to suit the kind of cut I am making.
Thanks, I think I'll spend my money on a roller guide instead.
Ian
   / Drag Tips for Plasma cutters #6
I really need to get a hand torch option for my plasma cutter.... i keep meaning to then i see the $600 price tag and forget about it.
there sure are times that i could use it instead of hauling out the OA setup.:mad:
Sounds like he has a machine torch for a CNC table. Don't know how many amps your plasma has, but this is the one on my 50a and it's less than $100, you'll just have to adapt the connections to your machine.
edit 80-100a, 25' cable, similar price
Edit 2... might be import duties on those. Also, the first torch isn't set up for HF, not sure about the second.
   / Drag Tips for Plasma cutters #9
I used to work in a fab shop we used drag tips all the time with a straight edge or homeade pattern all the time. a framing square works nice as a straight edge clamp it to the metal with a couple of vice grips. we would lau out the cut line with soapstone and then lay a line where to set the guide.
JG, how thick was the metal you were cutting?
Ian
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
GREENLEE 555C ELECTRIC CONDUIT BENDER (A51247)
GREENLEE 555C...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
John Deere 648G2 Grapple Skidder (A52384)
John Deere 648G2...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
