"drag link": alternatives, B21
   / "drag link": alternatives, B21 #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Is there an alternative to replacing the entire drag link (p/n 32721-57713), which goes for over $200 USD?
One end has an annoying bit of play in the end.
The ends look pretty much like "tie rod ends" but are welded and not threaded. I can live with it till it breaks, at that price.
I may attempt to find something close and do a cut and weld.
   / "drag link": alternatives, B21 #2
Buy some DOM tubing and tie rod ends and make your own. It might be the taper on the ends are standard but you'll need to measure them.
That crossed my mind, but this one has a curve or bend in it. I'll look more closely tomorrow to see if that really matters. I have no means of bending DOM tubing.
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
International 4700 Vibra Tiller (A51039)
International 4700...
