Drag Harrows
/ Drag Harrows #1
MrP
Central Florida
None: Sold Kubota L3410 HST 4WD
Anyone know where I can buy a good/cheap drag harrow? I have four horses on my properity and am getting tired of using a hand rake to break up the little gifts they leave behind.
/ Drag Harrows #2
Try TSC. They have some chain harrows of varying sizes and prices.
Terry
/ Drag Harrows #3
An earlier poster helped me out with this one (Thanks, Paul!), so I'll return the favor.
I have heard three different names for the type of harrow that I believe you are looking for:
Flexible harrow
Chain Harrow
and Drag harrow.
Assuming we're talking about the same thing, I'd point you to the same post Paul pointed me to:
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=108761&Search=true&Forum=All_Forums&Words=chain%20harrow&Match=Entire%20Phrase&Searchpage=0&Limit=50&Old=allposts&Main=108761>http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=108761&Search=true&Forum=All_Forums&Words=chain%20harrow&Match=Entire%20Phrase&Searchpage=0&Limit=50&Old=allposts&Main=108761</A>
Steve
/ Drag Harrows #4
<font color=blue>(Thanks, Paul!)</font color=blue>
You're very welcome - glad I could help.
/ Drag Harrows
Re: Any Links?
Any Links?
/ Drag Harrows #6
Furest makes a great flexible harrow, there are harrows avaialble at Atwoods also. Earth and Turf makes a drop spreader sized 60 and 72 inches, it is steel and will last forever, their phone number is 717-355-2276.
CHEAP---nope-----when it comes to tractors and real implements there is no such thing as cheap so you are out of luck, maybe a couple of plastic units strapped together from home Depot????? J
/ Drag Harrows #7
Many things will work for what you want to do. Cheap? Yes, if you find an old bed spring that you can drag around, and use the horses to do the dragging. Pretty? no.
Also, a chain link fence section will work great. Cheap - yes.
Tie a few pieces of lumber together that will drag and flop along on the ground - should work great for what you want to do. Cheap - yes.
Auctions of farmers will turn up a myriad of drag harrows that will be very cheap. And they will be adjustable so you can set the steel tines from flat to nearly upright, and get a variety of combinations of effects. These things do a great job on worked (disc harrow or plow) ground.
I would be surprised if any of these things would cost more than about $50.
/ Drag Harrows #8
If you have a pond and feed your horses sweet feed to, get some mallard ducks and you will never have to worry about the "cookies" again.The ducks break it down quick to get the grain.They even take care of it inside the barn. That's how I do it at my place. Of course though you will miss out on the seat time of dragging a harrow. /w3tcompact/icons/wink.gif
2010 GMC W5500 HD 16ft. Box Truck (A64556)
2010 GMC W5500 HD...
2022 EZ-GO ELITE...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
2016 VOLVO SD115B SMOOTH DRUM ROLLER (A65053)
2016 VOLVO SD115B...
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
