drag/harrow
   / drag/harrow #1
lil red
Im going to be dragging on dirt, just trying to even out the yard, and also the pasture to spread the manure out, I thought about a chain link fence but wasnt sure how to weight it, and make tines on it. Can you give the web for build it yourself.
Thanks for all the help
lil Red
   / drag/harrow #2
I use a "store bought" one, but I've seen people string 5-6' of chain link between a couple of posts and get pretty good results. I've seen nails in the front post for tines but I wouldn't recommend it. If they come out you could get flats from them.
   / drag/harrow #3
I used a disk. Disked till soil was like sand. Then hit it with a chain link fence hooked to R R ties. It did an OK + job. Fence came loose a couple times. Took a lot of time to do the fence tool. Today it's in pieces and if I want to make more grass land I'll have to spend more time rebuilding. If I had it to do over I'd look for an old harrow. Save time and $$ I believe.
Cheers.. Coffeeman
lil Red
   / drag/harrow #4
I was fortunate to know that a tennis court had been razed recently and got a section of heavy chain link fencing that was 8'x16'. I doubled it over to make a nice heavy drag that's 8'x8'. If I need more weight, I can attach some heavy timbers (cross ties) on top. For now, I just drag it with a chain attached to the drawbar. Eventually, I'd like to rig it up attached to a boom pole so I can lift it in transport.
I've seen great result from an old bed spring (the really old, heavy ones).
BR
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2017 Ford Explorer (A50324)
2017 Ford Explorer...
2016 GMC Sierra 1500 SLT (A50323)
2016 GMC Sierra...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2012 Cadillac SRX (A50324)
2012 Cadillac SRX...
