Draft Shafts for Trimmers
/ Draft Shafts for Trimmers #1
WillR
Oklahoma City
Terramite
What is the pros and cons for Steel torque tube drive shafts (Husqvarna 323 & 326) vs flex cable drive shafts found in most trimmers like Echo etc. I'm looking to buy a trimmer that will last me for years. I have a few acres, and I also take care a a few lawns beside mine, although I dont do lawn care professionaly. I don't care about the price, the Husqvarna 323L is what I'm thinking. Does the drive shaft on the Husqvarna give it an advantages over a flex shaft?
/ Draft Shafts for Trimmers #2
I have a gas trimmer with a flex shaft (Kyoti I think - am on the road these days). I purchased the unit in 2006 and am still using the "trimmer" with a new engine - the original engine died last year + I had to replace the bumper head as I wore it out.
/ Draft Shafts for Trimmers #3
I bought a higher end Echo with a solid shaft, which they said vibrates less than the flex shafts. I couldn't really tell the difference, but it was a nice unit. I use Stihls only now.
My beef with Stihl is they use 4 mix engines(4 stokes) now in the trimmers.
/ Draft Shafts for Trimmers #5
In the past, and it may have changed, only trimmers with solid shafts were recommended for use with brush cutting or saw tooth type blades. So if you plan to use one of these blades it might make a difference.
/ Draft Shafts for Trimmers #6
We sold Echo for 25 years and in all that time we probably replaces 2 or 3 flex shafts. Thats why Echo gives them a
lifetime warranty. For heavy blade use, go to a soild shaft.
/ Draft Shafts for Trimmers #7
What is the solid shaft made of? I have the usual collection of trimmers, but am not familar. Thanks
/ Draft Shafts for Trimmers #8
I have read that the flex shafts can eat through the shaft housing with prolonged heavy use.
/ Draft Shafts for Trimmers #9
Solid shaft is the way to go--flex cable is for the suburbanites who mow on the weekend.
I bought a professional grade Tanaka 8 years ago for about $400. I have 10 acres and 1/2 mile of fence line and ditch so I work my trimmer very hard. It finally lost compression so now I have an equivalent Red Max trimmer that is about $50 cheaper.
I got rid of the bump feeder (a PITA to load and prone to jams) and now use the clamp-type head that takes 16" long strings. I use the 0.155" size string--lasts a lot longer than 0.090" stuff that comes with most trimmers.
/ Draft Shafts for Trimmers #10
I bought a Tanaka with a solid-shaft. I also swapped out the bump-feed head for a quick-load head that uses .155" diameter line. It really rips through everything I've come up against. I don't have a big property, but I live in a golf course development next to a big retention basin. They don't mow/trim it as often as they should, so I keep the side near my property under control to keep the bugs and other critters at bay. I find that I spend more time running my trimmer out there than around my yard. I have a fully-fenced property and have to trim all around it at least once a week the way the grass/weeds grow here during the summer (rainy) season. I am hoping that it holds up to this much regular use.
/ Draft Shafts for Trimmers #11
This is true. The liners are replaceable, but for heavy use the solid "Steel" drive shaft is the way to go.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
Landhonor 48" Galvinized Fence (A66408)
Landhonor 48"...
Landhero 12-Ton Hydraulic Shop Press Machine (A66408)
Landhero 12-Ton...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
