Draft control???
   / Draft control??? #1
TCBoomer
Platinum Member
CT
New Holland TC24DA
I've heard the term and it appears to apply to a 2 bottom plow, but would someone like to enlighten me as to what it actually is or how it works.
Many thanks...
   / Draft control??? #2
A search of the forums for 'draft control' will result in a plethora of threads about this topic. Here's a link to one of them.
   / Draft control??? #3
You can read the 1000 pages of stuff to get a real good idea.
In brief.. draft control refers to a tractor that has draft sensing hydraulics. Draft is the force exerted on a ground engaging implement ( plow, box blade, disc.. etc ). From pulling it thru the earth. The higher you have your draft set.. the more pull that may be exerted on the implement. Exceeding that, and the hydraulics will work to reduce the draft usually by lifting the implement slightly. Draft control works usually through a spring loaded toplink..( like old ford N series tractors ) though there were other draft sensing hitches available on other equipment before the 3pt hitch was standard. This worked to help the tractor keep from breaking traction, and also added a safety feature.. Say you are dragging a plow and it encounters a rock.. the draft immediatly gets real high.. on a standard non draft hyd's.. the tractor would stall down..break the plowpoint, or backflip, depending on the hitch design.
On a tractor with draft control.. as the draft went higher than you had it set with the draft lever.. the implement would lift and avoid the obstacle..
Soundguy
   / Draft control??? #4
I have this on my TN.
In the picture you can see three levers. The one with a brown handle is a hydro remote. One of the others is draft control and the third is the three point lift.
The draft control works just like the other guys say.
I use it with my rear blade. This 9' blade can drag this tractor to a halt in 4wd if you take to much of a bite. So i set the draft control such that it lifts the blade a bit when it begins to strain the tractor.
The only negative with the setup on my machine is that since its hydraulic its a little slow in response. But a very handy thing to have for plows, blades, etc..
Fred
   / Draft control???
Thanks Mike...
That link also led me to a couple other related links as well.
I found what I was looking for.
   / Draft control???
Soundguy
Thanks for the brief version.../forums/images/graemlins/smile.gif
So now that I undrstand draft control and position control much better...
Any chance you can explain why the 3pt arms have 3 different positions? The RH arm link has a turnbuckle and the LH arm link has 3 holes. I know the position I am currently using is the float position...for the belly mower. Are the other 2 for fixed positions? If so, would that keep my york rake at a fixed position...and not ride up & over the material, if pulling too much?
   / Draft control???
Thanks for the reply and pic.
Bob
   / Draft control??? #8
Interesting picture - but what the heck is that big furry thing in the cab? My first thought was a geriatric Chewbacca, but I've never seen or heard of one driving a tractor...
   / Draft control??? #9
The 3 holes in the lh arm are simply adjustment... Highest hole lets you get the implement a bit lower to the ground.. also may help you to line up something.
As a dealer option some tractos can/had 2 turnbuckles .. one on each side for the lift arm links.
Soundguy
   / Draft control??? #10
</font><font color="blue" class="small">(
Any chance you can explain why the 3pt arms have 3 different positions? The RH arm link has a turnbuckle and the LH arm link has 3 holes. I know the position I am currently using is the float position...for the belly mower. Are the other 2 for fixed positions? If so, would that keep my york rake at a fixed position...and not ride up & over the material, if pulling too much? )</font>
Some items like a post hole digger you either want to raise the 3pt really high to get clearence or you want to get really really low to the ground with the lower arms. That's all the holes in the lift rods are for - to adjust how high or low the arms will raise.
Most USA tractors have single acting hydraulics, or float, on the 3pt, and there is no easy way to add down pressure.
That's a good thing, it does not work for blading nearly as well as you would think - rear wheels go up, no tration, you sit there..... If you need more down force with a blade, add a little weight to it, or get a bigger blade, or get a box blade with scarifiers.
--->Paul
2013 HINO CONV. ICE CREAM TRUCK (A52472)
2013 HINO CONV...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
7022 (A50322)
7022 (A50322)
2022 Kubota KX040-4 (A50120)
2022 Kubota...
35in Tooth Excavator Bucket (A50322)
35in Tooth...
