Draft arm float on 4010/2210
   / Draft arm float on 4010/2210 #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
The "rockshaft" (e.g. 3 pt) does not seem to have a float position on my 4010. Think it's the same on 2210s.
Directions in the manual when lowering the 3 pt are to run the rockshaft control down to where you want it and then return to the center position. This seems to lock the 3 pt into place, as my LX4 skids dig holes in the ground when the rear tires go into a small hole. What happens if I leave the rockshaft at the point at which I want the 3 pt positioned. Does this give me float, or will it do damage?j
For bringing the 3 pt up, the directions say to bring the rockshaft up and just leave it. When the 3 pt raises, the rockshaft lever returns to the center postion. Wonder why it doesn't do this when lowering it?
Ralph
   / Draft arm float on 4010/2210 #2
Your rockshaft should float when the control is in the middle position. Remove your mower and position the rockshaft arms somewhere in the middle range. You should be able to grab the draft arm by hand and raise it easily. If not, then you have a problem. The skids on your mower may gouge the ground if it is soft. The mower is heavy and you are carrying the weight on the skids when they bottom out. Do you have the mower leveled properly front to back?
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
Toro Workman Utility Cart (A51694)
Toro Workman...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
