DR Power 3-pt logsplitter
/ DR Power 3-pt logsplitter #1
randyny
Just an informational thread. There is precious little info on the Timberwolf 3ph splitter or the DR other than what I can read of the respective web pages.
I needed to replace my ~25 y.o. Sears 5hp, 6-ton splitter so decided to go with a 3 point PTO powered model to put on the Simplicity Legacy XL. I've been thinking about them for a while, but the only model I saw was a Timberwolf model. The DR model was not quite as much, but looked mighty nice. Turns out, the DR is sourced by Timberwolf! There are Timberwolf stamped parts on the unit, the instruction book has the same wording, even the model number of the DR is the TWDR-3. The Timberwolf is the TW-3. (I recently noticed red paint underneath the orange DR paint too) The only significant difference I see is the DR has a narrow wedge instead of a wide wedge. No 4-way wedge yet as DR had them for 179, which is a silly price.
I picked this up at a drop location to save $100 on shipping. The crate took almost the whole bed of the F-150.
The pump (a Prince 20gpm) is ridiculously heavy, and just fits within the PTO shield. Sadly, I thought this snugness would let me get away with no torque chain. First movement of the lever resulted in the pump making a pretzel out of the guard. Lesson learned.
This one is a 17 ton unit. The 6-ton I had (visible in the background) worked fine for virtually everything I put through it so I didn't feel the need to go with a bigger unit. I, as everyone else, was concerned about ram speed (the Legacy XL has a 5.1gpm pump) which is why I went with the separate pump. I also thought about saving some bucks by buying a basic 3ph model, then adding the pump/tank/hoses/etc., but decided it wasn't worth it in the end.
I split maybe 1-1/2 cords so far. I run the tractor at a nice, purring ~1600 rpms. I like being able to lower the unit to the ground for the big logs, and raise it up to save the 'ol back. It does have auto return which I find I don't use all that much. It's quieter than the engine powered unit, mainly because I'm so far away from the motor now. I personally don't use the loader when splitting - I prefer to split at the pile and stack as I go so that's not an issue.
Net result is it's a pleasure to use, but because it's so fast the unit has a high cost-per-hour rate. That's ok, because this will truly last a lifetime or two, and I typically will split 3 or 4 days per year to make that year's supply of firewood.
Plus, it's super-cool (to me) to have yet another attachment I can run off my tractor.
Anyway, some action photos are attached.
/ DR Power 3-pt logsplitter #2
I had been looking for some info about this. I want to build one but didn't know where to go for the pump??? I hope you don't mind my asking, what did you pay for this splitter?? Maybe I don't want to waste my time building one!!!
Also I'm assuming I can do a search online for Timberwolf. Not so sure about DR, what does that stand for or what is their website address?
Thanks for posting this thread, very informative and great pictures!!! :)
DR Power is also known as Country Home Products, based in Vermont. It cost 1595. Alas, as I attach this link:
DR® Power Equipment -
I see the price went off sale - back to normal at 1900. For 1900 I wouldn't have bought, but DR has sales seemingly every quarter.
Rough prcing I've found for compnents were 5-700 for the 3ph splitter, ~400 for the pump, ~100 for a hydraulic tank, plus the hoses ~100, plus filter, pressure gauge, and then building it correctly. It would be anice project, but I have other projects I should devote my time to at this point.
rp
/ DR Power 3-pt logsplitter #4
Surplus Center has the for about $400.00...You just need to find a splitter with a blown engine for sale CHEAP!
/ DR Power 3-pt logsplitter #5
What is the DR. up to now? I could stay warm all winter by burning all of the junk mail that company sends me! My mother in law has one of their walk behind string trimmers. Sometimes I wish she would walk in front of it!!!!!! ;)
I actually enjoy getting their catalogs to see what new and exciting things they got for me. I also have the leaf vac which is a pretty slick unit.
/ DR Power 3-pt logsplitter #7
randyny... what is the cycle time on the splitter? thanks, John
They claim 6-seconds. It may be 6 seconds one way, but I figure cycle time to be both directions, so 12 would be more like it. It's actually quite fast, and probably only run the unit at 50-60% speed, based on PTO speed.
I also just realized that the 4-way wedge will triple productivity rather than just double it, so maybe 179 bucks isn't so much after all.
/ DR Power 3-pt logsplitter #9
In general, unless you can scrouge most of the parts for free, you can't build one for less than a commercial will cost. Just the price of the hoses brings on sticker shock. I had to buy the hoses and motor and still had a bunch of money into it by the time I got up and running.
Building yourself does have the advantage of being able to design it the way you want it and add niceties (lifts, tables, etc). One thing I did on mine is put the 'works' pump/motor, reservoir, axle and wheels at the very end of the armature. Keeps them out of the way of the operator. I haven't seen any commercial 'tip-up' models that don't have a bunch of stuff right where the operator needs to stand.
Harry K
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
Ford 7000 (A64127)
Ford 7000 (A64127)
