Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #51
The difference for me was somewhere around a grand I believe. I will have to look and see what the exact amount was when I get home. Im sort of curious. My wife has been very impressed so far. We keep starting to beat ourselves up over buying the L but then we remind ourselves we made the best decision at the time.
You are really gonna love how quiet the drive is. I know it rides alot better too. I imagine most of that is the weight of the tractor.
Have you put anything on the 3pt yet and tried to raise it slowly?:)
I am hoping that the DK will be some better than ole "jerky":)
James K0UA
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #52
James K0UA
The DK 3pt is very smooth IMO. It is also very nice to be able to make very small adjustments from the back lever while standing off the tractor and attaching something to the hitch. The lever in the back is pretty long which makes fine adjustments easier.
James K0UA
Sure have. Been using a wood chipper and it is smooth as silk pie!
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #54
cool!
The extra weight sure came in handy tonight when we where using the ratchet rake to rip out some shrubs. However I did get to see the weakness of R4 tires instead of Ags. Although the lawn sure is happier!
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #56
Are you using 4 wheel assist? You almost have to use that with R4s if you are doing any ground engaging work. Ballast also matters and I forget if you have loaded tires or not. I always have a 3PT implement on just for weight.
I was using 4 wheel. I have loaded tires but I didnt have anything on the rear. The R4 s did a good job but this is the first tractor I have ever operated that had them. So I just have to learn their limitations. Sometimes I hard to take two runs at a shrub to rip it loose.
k0ua said:
The really disgusting part is I paid within 300 bucks of the DK35se for the L3400HST and this is 19 months later.
James K0UA
I forgot about my homework for last night! The base price (no taxes implements or loaded tires) of the L3700su in October of 2010 was 18075. Base of the Dk40 was 19747. So a diff of 1672 bucks. Factor in 2 or 3 price increases of a couple hundred bucks over the last 17 months or so and I bet the difference is less if we were able to truly compare apples. I really need to get working on that time machine!
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #59
so is the best thing to do just break it off and throw it away upon delivery?:laughing:
Or carefully remove it (if the the delivery ride did not already do that) and save it for trade in time and put it back on?
James K0UA
No...just back it onto the trailer:D
   / Dr Orangelove or: How I Learned to Stop Worrying and Love the Kioti #60
With shrubs and the DK40 it is usually better to use the loader to pop them out rather than push them over. I typically push just enough to expose a riot then stick either the grapple or a toothbar under the bush and curl/lift the bush out. Saves the turf from spinning wheel damage. The KL401 is powerful enough that you don't need to push much at all.
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
