Chipper DR Chipper Reliability
   / DR Chipper Reliability #11
No problem.....BTW, you don't have a lot of time. I ordered mine in March and it is finally at the dealer.
WOW! Four months! From the site, I assumed I could order through the 800# and have it shipped. Would do the same with the DR. Is this not possible,or did you have a special circumstance that delayed it this long?
   / DR Chipper Reliability #13
They order them from China and have them built and shipped. They do need to wait until they have enough for a cargo container. Call them and find out if they already have an order in with extra chippers.
   / DR Chipper Reliability #15
Last year I bought a PTO powered chipper from Homier(.com) for about $1,300 plus shipping (can't remember the amount). If I remember correctly, I think it is the FarmPro brand and they claims it can chip up to 6" material. It has an automatic feed too. I had it shipped to a terminal location and picked it up using my small utility trailer. It weighed about 1,000 lbs, it wasn't too bad to assemble and hooked right up to my 3PH. I used it to chip 1" to about 5" fresh cut and long dead saplings. I don't doubt that I had a number of 6"s in there too. It worked great and I chipped many hours per day for about three weekends. I am very happy with my purchase.
   / DR Chipper Reliability #16
I think the DR powerline has a belt or chain link between the PTO driveline and the flywheel, whereas most other chippers have a direct mechanical connection. I think this is partly why the DR is so much more lightweight. I could be wrong on this, bit think it's correct.
Give a look at http://www.salsco.com/woodchippers.htm
   / DR Chipper Reliability #17
what about this Salsco chipper. how well does it work. what is the price range for their model 600/624 they look like decent equipment on their web page. how fast can you get these or do you have to wait for a cargo boat like the Jimina thanks for the input
Wow, those Salsco chippers look pretty HD! Does anyone have a source for prices? I didn't see anything on the site, but by the looks of them, they're not cheap!
   / DR Chipper Reliability #19
MFL,
I picked up the chipper yesterday and put it together this morning. I was surprised that it took less than an hour to put it together. I made sure to tighten all the already installed bolts as I was putting it together (air power is great). This thing is really a beast. After lubing and changing the oil I put it to work for a short period. 5-6" limbs are not a problem. The chipper didn't stutter. I am going to make a minor change to the feed linkage. It just doesn't look like it will hold up. I'm going to add a couple set screws to it when I get a chance. Overall, looks like it is a good investment.
Rick
   / DR Chipper Reliability #20
The Homier is the Farmpro ( which is an arm of Homier) and is the Jinma or emorybuilt. I've looked and lusted but I am concerned about the weight. I've got an older Hinomoto E18D(massey 205) It's fine for what I need but I wonder whether the 3ph can deal with 1000 lbs.
skaning1
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2015 CASE CX300C EXCAVATOR (A52707)
2015 CASE CX300C...
2011 GAYLEAN 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN 130...
