DPF De-rating issues
/ DPF De-rating issues #1
Sheepacres
2021 X1.35 McCormick
Hello all, looking for some additional advice. I have a 2021 X1.35 McCormick Tractor. It does not get used often during the winter months, but when I do use it I was not keeping the throttle up where I should have. Now that I am trying to use it more often, I am trying to keep the throttle at full, however and it will not stay at 2500 rpm for very long before it starts de-rating down to 1500-1800 rpm. I removed the DPF filter and cleaned it the best I could, and put it back, it still does the same thing. One shop I called said that it needs to regen and I should try that 2-3 times, but I thought it needed to be at full rpm to reach the correct temperature for a regen. Today I let it run full throttle for about 2 hours, but it only went to 1500-1800 RPMs. What do I need to do now?
/ DPF De-rating issues #2
Hello and welcome to TBN.
That tractor is just a rebranded Branson 3520 or 3725. Which means it uses the Kukje/Cummins mechanically injected engine, which also means there is no electronics on it and no way for it to derate.
I say your issues is most like fuel or air related. Have you check your air and fuel filters? How long it has been changed?
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
30 Yard Roll Off Dumpster (A65579)
30 Yard Roll Off...
