Dozer Blade or Grader Blade?
   / Dozer Blade or Grader Blade? #11
That really doesn't sound like tractor work to me... I've been doing a lot of work lately with a dozer and trackhoe, same soil conditions you describe. Even the 10 ton dozer with tracks would have it's work cut out for it cutting down trails on hillsides. I would absolutely not recommend a dozer blade on the front for packed material.
I would lean towards a loader with a toothed bucket and some type of very heavy rear adjustable blade, if all I could use was a tractor.
A dozer isn't in the cards. Just my tractor with a front blade or rear.
There's also no trees. I need to make flat walking paths on clear hill sides.
   / Dozer Blade or Grader Blade? #13
I understand and was just speaking to capability. After the many dozens of hours I've spent operating a dozer and becoming familiar with operation and capability I would not recommend a front blade for anything but extremely light and loose material. Silage, snow, or just pushing brush is what comes to mind.
You might get away with a turning plow to start your hillside trails. Turn down from the high side to create a shelf then use the bucket and rear blade to level?
   / Dozer Blade or Grader Blade? #14
Try a HD box blade with rippers and always pull down hill.
My personal observation is you pay for it in the long run either way. Just seems less painful to use a small machine if you don't consider fuel, time, wear and tear,...
   / Dozer Blade or Grader Blade? #15
If that's a 100 HP tractor I would think you can do pretty much anything with it you need to other than maybe moving rocks. I would get me a good size box blade and go to work. It won't be as fast but it will be affective.
I thought about cutting into the hill like that, but then that's one more thing to get. Shaving of a bit at a time with the corner of a tilt blade would get it I was thinking. I was planning on working it down until I got a flat path to the observatory and other trails.
I've got 1000s of feet or trails to make on hill sides. I have to be able to drive straight.
105HP 4WD to be exact!!!! Haha. I figured it do anything I needed for this project. The rear blade with a tilt would probably work too.
   / Dozer Blade or Grader Blade? #19
I'm not much of a fan of a rear blade. They tend to just not be heavy enough. TNT would be a really good adder with a box blade and scarifiers. I also have a landplane that I made which I use more than anything but it's primarily for leveling. Mine does a pretty good job moving dirt from A to B but since I don't have tines for it, it doesn't dig like my box blades do. I pull a 7' box with my 100 HP.
The tilt is crucial. It's the only way to cut into the hills on long stretches without using my 3pt backhoe and taking a year.
In 1st gear I should be able to pull an 8ft blade in front or back, I think.
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
FRONT MOUNT POLY TANK W/ MOUNT (A52708)
FRONT MOUNT POLY...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
HYD BREAKER FOR MINI EXCAVATOR (A58374)
HYD BREAKER FOR...
