Downspout drains
/ Downspout drains #1
RebelYell
East TN, Limestone(between Johnson City and Greene
Kubota BX22
I started this work last week and took a few pics. In this pic I am just starting. If this machine was any bigger then I would be shoveling throuh this area. I finsihed putting in the drains and have somewhat leveled everything off. I didn't take alot of pics and I still want to add a few to this string. I plan on installing another sump pump in the field. The hole I dug for this water to dishcarge into is about 4' by 6' and 4' deep. The water level is about 2 feet from the top so I will definately have to add a sump pump. The hole is close to the springhouse. I have a sump pump in the springhouse which runs water out to the creek about 12 hours a day. I want to build a pond behind the springhouse someday and feed it with the spring. If the springhouse wasn't in such good shape then I would tear it down and have a pond there.
/ Downspout drains
I dug the drain out from the corner of the picnic area and under the shelter for my wives hammock. Yep, I might as well call it her hammock because I never got to lay in it this past summer. What was great was the little Bota could fit under the shelter so I didn't use a shovel for anything. I wasn't going to do this but I will. Just past the tree is a pipe running from the house to the springhouse. I knew it was there, or at least the vicinity it was in. I started running into roots from that tree, which I am cutting down because it must have been rootbound when it was planted by the former owners. Well, I got tired of chopping the roots so I got a bit tougher with the BH. I saw a small stream shooting into the air and thought I busted a hydraulic line. Then I noticed it was water and knew exaclty what it was. My ditch filled with water fast before I could get the water turned off. Pumped the water out, repaired the line and got back to work.
/ Downspout drains #4
I hate it when a tractor project turns into an unplanned plumbing project! Sounds like you handled it well. Good job.
/forums/images/graemlins/laugh.gif
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
(6) 250 Gal Chemical Containers (A64127)
(6) 250 Gal...
Lifts (A61567)
Lifts (A61567)
