Downspout drainage
   / Downspout drainage #11
I would dig a dry-well 30 feet out and dump my downspouts into 4 inch pipe to feed the dry well. Rain barrels are a great idea too but in the winter you have a new problem
   / Downspout drainage #12
Racer71 said:
Start your bend higher up the wall and go towards a different corner. This may not look as nice but the water will go away.
This seems to be the best solution if the original poster does not want to sump pump. Divert it to a different corner of the house that has better drainage. You need to get it away from the foundation.
   / Downspout drainage #13
I was facing a similar situation and solved it by moving the gutter outlet to the opposite side and changing the slope of the gutter to flow in the same direction. Fortunately, in my case there was another gutter outlet around the corner which I was able to tap into.
Another problem area I am currently facing is a corner of the garage against a bank that was dug into a slope to make room where the gutter installers decided to place the downspout in the corner and let it drain onto the foundation. I plan to solve it in much the same manner except that I will be digging a 3 foot deep trench across the driveway and installing 4 inch PVC to carry the water away. I have to dig the trench so deep because the driveway is beveled against the slope to prevent erosion.
Just remember that water always flows downhill and that solving it sometimes has to be done above grade or by digging a little deeper.
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
Towable Message Board (A55787)
Towable Message...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
