Down side of belly mower
   / Down side of belly mower #1
tld
Boston, GA
JD 2025r
I have a 4110 and a bush hog 60 in finish mower. Was considering a belly mower. All I have to mow is about 6 ac of pasture which is always fairly low...6 inchs. Really front lawn.
What are the downsides of a belly mower?
   / Down side of belly mower #2
They are difficult to put on and off. Other than that, I can't think of a downside. I use the 72" mid mount mower on my 4300
   / Down side of belly mower #3
Trees or objects to navigate around?? Belly mower is easier. Nicest cut available. Sure is easier putting on a 3pt mower, though. I vote belly. I use 72" midmount.
   / Down side of belly mower #4
They cut nice and some are easy to get on and off. I have the 72D Autoconnect - Literally a minute or two to take on and off, as long as everything is adjusted correctly and lined up. Very easy to trim around trees, etc. I replaced a 72" 3PT finish mower and have no regrets.
This is a 7 yr old or so 4110 so I don't know how easy it is on and off. Will have to talk to the dealer. Cost might be another factor.
   / Down side of belly mower #6
They aren't too bad to take off. I have a 72" on my 2520. Works best if you have a concrete area you can roll it out on. I can have it off in 10 minutes or less after the first time or two figuring it out. Just need to turn 3 of the gauge wheels half a turn and pull the pins on the 4th one and remove it. rolls right out from under the tractor with ease then.
   / Down side of belly mower #7
My two cents... it all depends on the property you're mowing, your particular tractor/attachment system and what elese you use the tractor for. On my tractor, a 955, removing/installing the MMM is a bit of a pain and I don't have a nice flat concrete area to do it. That coupled with using the tractor for loader/dirt work, backhoe work, grading... I'd have to take the remove/install the MMM deck one to two times a week. For these reasons, I went with an RFM. The downside of the RFM is there are just some places I cant get to with it and still have to use my smaller tractor with a MMM to trim.
   / Down side of belly mower #8
What size tires do you run on your unit? I am considering getting a used 72D Auto-Connect deck for my 3520, but I may have to switch back to my original tires R4s, instead of my, stable, R3 Turk Special tires. I am hearing the right rear castor is the problem - its a clearance issue for the Turf Specials.
   / Down side of belly mower #9
they make a tractor look like a "lawn tractor"
   / Down side of belly mower #10
I am running the standard R3 tires. My dealer advised me that the R3 Turf Special tires would not clear the deck.
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
