Doubt I can get this old Cletrac running...
   / Doubt I can get this old Cletrac running... #131
Yes sir, this is not for show. I do fully intend to put this machine back to work. I've got an embankment to build up. LOL
IMO...your work on this machine ranks right up there with the most accomplished projects in the TBN archive...
When you run this machine it is hard to imagine a more rewarding experience on a personal scale...IMO it is one of the most interesting continuing threads...Thanks so much for taking the time to take the pics and explain things in the narrative...
Hang in there we're all pulling for you...I guarantee a bunch would have given up long ago or would have not even considered putting a wrench to it the way it sat in the OP...
:thumbsup: :thumbsup:
   / Doubt I can get this old Cletrac running... #133
If you are just gong to drive it around for the fun of it and not work it hard then the gears are good enough the way they are.
Maybe the left and right bull gears can be swapped, like the drive sprockets.
   / Doubt I can get this old Cletrac running... #134
that would not work, since the full width of the gear gets engaged. and one half of a tooth is missing, that will be the first to go, and the tractor can't move with that tooth missing, unless you like to drive in circles, using the intact gear on the other side..
   / Doubt I can get this old Cletrac running... #135
I was looking at your missing tooth on the gear and googled up some stuff on repairing gears. Found this interesting video. Of course, not many of us have this equipment sitting in our shops, but someone, somewhere does. hahaha
Anyhow, the process is very interesting.
   / Doubt I can get this old Cletrac running... #136
this is an "on the cheap repair" cast iron is very strong, and to see teeth chip off on it, indicates this gear can see very large loads sometimes. putting bronze teeth on it just don't make sense. it would have been much better to just make a new gear in this case.. since the machinist is not fully confident in welding cast iron.. since he has only manual machines, it would take much longer to make a full gear, as opposed to using a CNC gear hob to make this gear.. this type of repair, using bronze would not be suitable for repairing the gear on the Cletrac, there's way too much pressure on the teeth of this gear..
radios1. Thanks for the links. I’m on the cletrac crawler FB page which has been a big help.
As for the bull gear, I have located one in good condition that has no damage. It’s on its way. :). I’ll be taking the other final drive apart hopefully in a week. Biggest hurdle is again, breaking track on that side.
   / Doubt I can get this old Cletrac running... #138
Great news. What did it cost?
Your old gear looks like some foreign object got in the box, and caught in the teeth.
   / Doubt I can get this old Cletrac running... #139
I didn't say it was the right way to go. I just said it was very interesting. And from watching that video, I gained some appreciation for how much work would be involved in making a brand new, all from scratch, gear for some piece of equipment where no parts are available, let alone just a repair on a couple teeth. Fascinating process.
   / Doubt I can get this old Cletrac running... #140
I totally agree, and I just made the mention so others don't make a mistake..:thumbsup:
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
Kivel Pallet Forks (A53316)
Kivel Pallet Forks...
2239 (A51244)
2239 (A51244)
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
