Double Your Bota, Double Your Fun
/ Double Your Bota, Double Your Fun #21
Harv
I agree that you must feel safe when doing anything on your tractor. The wise say if it does not feel safe for you it is not safe. Knowing your land has a lot to do with knowing the limits of your tractor and of you. The only problem I have is putting too much faith in a add on meter as a way to indict safe slopes, if there is any safe slopes. If you think a slope is too steep, why would you drive your tractor on it to read the meter. I would mount the meter on a long 2X4 and lay it on the slope to see if it is too steep. A 2X4 is cheaper than a tractor. On response was stating about doing tipping test to find angle of tip over. You can by using a little physics determine the point of tip over by calculating the angle in which the gforce is greater than the normal force, but again I see acceralection a bigger problem than the gforce being larger than the normal force.
Dan L
2018 INTERNATIONAL LT625 TANDEM 6X4 SLEEPER (A59904)
2018 INTERNATIONAL...
9000 (A47477)
9000 (A47477)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
John Deere 6110M (A60462)
John Deere 6110M...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2003 FORD F150 HARLEY DAVIDSON EDITION PICKUP TRUCK (A59905)
2003 FORD F150...
