Double Chipping? And MDF?
/ Double Chipping? And MDF? #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I'm thinking about 'double chipping' some piles of wood chips for a smooth walkway on a couple of trails. Anyone doing such a thing?
Also, I have a supply of used MDF used shelving that I would like to dispose of in the same manner. Is there any drawbacks to chipping MDF 'lumber'? My concern is that it might dull the chipper blades...
/ Double Chipping? And MDF? #3
If your chipper doesn't make small enough pieces on the first pass, I would adjust the chipper, change the exist screen, or check that your chip breaker is still functioning. (BTDT, mine lost one of its two "teeth" and it made a big difference in chip sizes.)
Double passing chips tends not do much in most chippers, unless yours is a hammer mill type chipper/shredder, in which case you probably want a finer screen on it.
All the best,
Peter
/ Double Chipping? And MDF? #4
No matter how you use your chipper - simply using it will dull the blades. I've never considered "double chipping" my pine chips. Time will always reduce the chip size. Particularly if used on a traveled way.
  • Good Post
Reactions: JJT
/ Double Chipping? And MDF? #5
When the power company trims trees I try to get some of their chips. The chips are not pretty or consistent and I do wind up with some real stringy stuff. But the price is right, I spread it thick and it does seem to break down and makes nice walking and driving path.
This year I hit the jackpot. They had a list and were rationing the loads to make sure everyone on the list got some. I told them I would take all they could give me. I wound up with eight loads! I live in the country, on a cul-de-sac. So quiet road, plenty of room to drop the chipper and an easy dump.
So, I guess I am saying, in my opinion you are going to a lot of extra work for limited benefit.
Doug in SW IA
You're right about simply slowing down the chipper feed speed. Simple solution.
Regarding chipping MDF - not a good idea either. The chipper totally mulches the MDF planks, but, in my case, I ended up with a pile of mush mixed with a bunch of non-degradable plastic from the trim. At least I was wise enough to try only one plank, which I ended up shoveling up and putting it in the trash.
Thanks for the responses.
Bobcat T590 (A60462)
2008 Ford E350 Armored Car (A64047)
2008 Ford E350...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
Caterpillar 416 Backhoe (A64047)
Caterpillar 416...
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59911)
1980 FRUEHAUF 45'...
John Deere XUV825E (A61307)
John Deere XUV825E...
