Door Won't Stay Open
   / Door Won't Stay Open
Yep, Jeff, that looks like a pretty good idea.
   / Door Won't Stay Open #12
I was also gonna suggest bending the hinge pin, but others beat me to it. I'm a trim carpenter and sometimes when the painters take the door slabs down to paint them they don't put'em back up correctly. So I run into this on a regular basis and bending the pin almost always does the trick. Soild core doors are more finicky about swinging on there own if out of plumb than hollow core ones.
Is that just because the solid core doors are heavier? Or is there some other reason that I don't know about?
   / Door Won't Stay Open #14
Yes because they're heavier. Also I like to use screws through the hinge and into the cripple with solid core doors. Those little short hinge screws just don't always cut it.
   / Door Won't Stay Open #16
Did you check for poltergeists lately:D
That's a good idea. Ever since I moved into my house I put the chicken in the middle shelf of my fridge. When I'd wake up in the morning for some reason it would be on the top shelf. Took me forever but I finally figured out that I had a poultrygeist.
I knew I had gremlins in my shop down in the country that were always moving things around and hiding my tools, but I didn't think about poltergeists here in town.:D
   / Door Won't Stay Open #18
I think I need to install a video camera in the shop so I can replay the tape and find my tools.
   / Door Won't Stay Open #19
I am so glad Bird asked how to fix this problem! :D
I took out one of the original door hinge pins and put in a replacement that has a door stop attached. As soon as I did this the door has trouble staying open. :eek: I will pull the pin out and bend it. :D The problem got worse when I oiled the hinges to stop squeeks. :rolleyes:
Thanks!
Dan
Dan, our bathroom door stayed open until I lubricated the hinges to stop the squeak.:D So I bought one of those little rubber door stops (wedge type) to keep it open. Don't know why I never thought about bending hinge pins a bit, but it worked.
Just no end to the kinds of information and help you can get on TBN, tractor related or not.:)
2024 CATERPILLAR 242D3 SKID STEER (A52705)
2024 CATERPILLAR...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
17101 (A55787)
17101 (A55787)
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
