Door Won't Stay Open
   / Door Won't Stay Open #1
Bird
Rest in Peace
Corinth, Texas
When we bought this place about three and a half years ago, the hinges on one bathroom door squeaked. A little shot of WD-40 fixed that. But it's never stayed open since then without a door stop.
It swings almost, but not quite, shut. It stayed open before I fixed the squeak. The door fits into the frame very well, latch works fine, etc. I might be able to adjust a hinge; put a shim under the bottom and center hinge (3 hinges). It seems that the best solution would be if I could find something just very slightly sticky to put in the hinges.
It wouldn't take much to get that door to stay in whatever position you leave it, as all the other doors in the house do. So what solutions would you recommend?
   / Door Won't Stay Open #2
Open it all the way and nail it to the wall behind it.;) If that's too subtle, put a level to it in all three planes and see what you get. Is it possible some of the screw holes in the frame have enlarged, allowing one hinge to move forward/backward from the plane of the door? Your shims would compensate in a different plane.
   / Door Won't Stay Open #3
Put a level on the hinge side door jamb, checking the vertical in two orthogonal directions, then shim the hinges to compensate. The only other solution that I can think of is to pull the trim and shim behind the hinge side jamb. That is why I use screws to install door frames, to make future adjustments easier when needed. I use trim head square drive screws for this application and find it is easier to dig the paint out of the recess than Phillips head.
Vernon
Vernon, that's exactly the problem. I just discovered that the door jamb is not exactly vertical. I shimmed the middle and bottom hinges with thin cardboard just now, but that was not enough to do the job. The opposite door jamb is also off by about the same amount, so I'm not sure yet whether I can shim the hinges enough or not and still be able to close the door.:D And before I mess with it anymore, I want to get some slightly longer screws. Eeverything looks good now, so I'm sure not going to pull the trim and shim behind it. It ain't that important. If you open the door and walk away, it will slooowly swing around until it's open about 12" and stop there.
   / Door Won't Stay Open #5
A trick used by mobile home builders is to slightly bend a hinge pin. The door won't swing freely then; it stays open when you want.
   / Door Won't Stay Open #6
Buy a pair of rusty hinges.
   / Door Won't Stay Open #7
Hello Bird,
Long time since we "talked". Hope all is well with you and family.
I found a "spring" gizmo that fits on the hinge by removing the pin and then using a "included" spanner type wrench tool to adjust the tension.
We've had one on the backdoor for years and it slowly closes the door.
If this explanation is "clear as mud" let me know and I'll take a pic and post it.
Edit: Duh, you said "stay open". I don't know if it can be set to keep open.
OK then tack a small piece of foam to the bottom that just touches the floor.
   / Door Won't Stay Open #8
Hello Bird, ^^^ That will work for you. Just pull a pin, lay on the concrete, smack it in the middle with hammer, reinstall and the door will stay open. Terry
Thanks to everyone. Reb, we (or at least I) sometimes overlook the obvious. I posted this question on Countrybynet, also, and the bent hinge pin is what Egon said to do, so I did it and that seems to have fixed it.
   / Door Won't Stay Open #10
I've got an issue when the windows are open with a breeze blowing the door shut. I'm planning on replacing all the doorstops with something like this to help out. Could also help you if the bent hinge pin doesn't fix things.
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
LOT LOCATIONS (A51219)
