Door handle for Kubota MX54 factory cab.
   / Door handle for Kubota MX54 factory cab. #1
Rhazel131
Ford 1500
Does anyone know of a door handle kit for the right hand door so you can open it from the outside? Our local dealer says one is not available sine you cannot enter from that right side.
I feel it would make it much more convenient when changing implements to simply open this door and reach in to adust loader, lift etc.
   / Door handle for Kubota MX54 factory cab. #2
I am assuming you have a Kubota MX5400, since the MX54 is not a valid model. The door latch on the MX5400 left door appears to be the same as the Kubota B3030. The B3030 has a handle for the right door I am guessing that they would work on your right door.
Below is the diagram for the B3030
The latch is T0270-86010. You will need the parts listed below as well.
07003014-50620SCREW,PAN HEAD(PHILLIPS)2 >=11337 0.011
080TC860-85150COLLAR(DOOR)2 0.0066
09002014-50060HEX.NUT2 0.0044
10004013-50060WASHER, PLAIN2 0.0022
110TC860-85172STAY(DOOR,LOCK)1 <=16164 0.33
110TC860-85190STAY(DOOR,LOCK)1 >=16165 0.506
110TC860-85192STAY(DOOR,LOCK)1 >=16862 0.506
120T3685-84530BRACKET(REARLOCK)1 0.022
13003054-50514SCREW,PAN HEAD(PHILLIPS)2 0.0088
140T0270-70890NUT,DOOR STRIKER1 0.1276
15030810-18870BOLT,FLANGE2 0.0264
160TC860-85200LEVER(DOOR,LOCK)1 >=16165 0.154
160TC860-85202LEVER(DOOR,LOCK)1 >=18051 0.154
17004015-50080WASHER,PLAIN2 >=16165 0.022
18037560-44880SPRING2 >=16165 0.0044
19002552-50080NUT,LOCKING1 >=16165 0.011
200T0270-61610COLLAR
The link to the kubota parts book is below.
UNUSED WOLVERINE PFF1-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2016 John Deere 326E (A47477)
2016 John Deere...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
