Don't bend your telescoping links!!
   / Don't bend your telescoping links!! #11
Re: Don\'t bend your telescoping links!!
Randy,
The individual part numbers for telescopic arms are: (to order separately)
LVA10606(RH) AND LVA10607(LH)
The whole kit part # is: LVB25072
<A target="_blank" HREF=http://jdpc.deere.com/pimages/MP24/MP24451________UN09FEB01.gif>JD 4400 3-point hitch parts</A>
4200/4300/4400 COMPACT UTILITY TRACTORS
Page Name: THREE POINT HITCH
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 M123745 PIN 1
2 19M7865 SCREW 2 M8 X 16
3 AM125811 SUPPORT 1
4 24M7055 WASHER 1 8.400 X 16 X 1.600 MM
5 11M7080 COTTER PIN 1 2.500 X 16 MM
6 CH19220 SPRING 1 (W/O CAB)
M136396 SPRING 1 (W/ CAB)
7 AR62150 QUICK LOCK PIN 4
8 34M3851 SPRING PIN 2 4 X 24 MM
9 AM119697 CENTER LINK END 1 LH THREAD
10 CE17590 PLUG 2
11 AM119699 CENTER LINK 1
12 14M7278 NUT 1 M24
13 AM119698 CENTER LINK END 1 RH THREAD
14 CH11409 PIN 1
15 CE17307 SPRING PIN 1
16 CE18325 LIFT LINK 1
17 T21901 BALL 1
18 M120789 LINK BODY 1
19 RE42504 HANDLE 1
20 JD7798 LUBRICATION FITTING 1
21 99M7016 PLUG 1
22 M120791 YOKE 2
23 AM126169 LIFT LINK 1 RH
24 M120905 SPRING PIN 1
25 M90337 STOP 4
26 AM126167 DRAFT LINK 2
27 A3581R SPRING LOCKING PIN 2
28 CE18326 LIFT LINK 1
29 34M7030 SPRING PIN 1 5 X 20 MM
30 M120791 YOKE 1
31 T21901 BALL 1
32 JD7798 LUBRICATION FITTING 1
33 99M7016 PLUG 1
34 AM126168 LIFT LINK 1 LH
35 M124515 PIN 2
36 M136500 WASHER 2 -XXXXXX (NLA)
37 14M7328 LOCK NUT 2 M16
38A 19M7794 SCREW 2 -XXXXXX M16 X 50
38B M138943 BOLT 2 XXXXXX- (SUB FOR M136500 AND 19M7794)
39 M136096 PIN 2
40 AM126932 STABILIZER 2 FEMALE
41 AM126866 STABILIZER 2 MALE
42 M137645 PIN 2
43 M120514 RING 4
.. LVB25072 KIT 1 DRAFT LINKS, TELESCOPING (INCLUDES LVA10606(RH) AND LVA10607(LH)) (NOT SHOWN)
John,
Thanks for trying. Ya sure had me excited for a minute. Called my J.D. dealer, he punches in the part number, it lists just like you have but when he tries to enter that number for an order, it says "not available" . "Only available as part of kit #LVB25072". They also don't understand why they can't order one side only, especially since it lists a separate part number.
Hoss
   / Don't bend your telescoping links!! #13
Has the dealer offered to sell you just the link you need and keep the other one in stock or return it to JD?
No, he hasn't. But I don't hold that against him. They have been really great about everything. When I ordered the tractor, I didn't order it with the telescoping links. I decided after the first couple of weeks that I had made a mistake and ordered them. He let me trade in the old ones to save me some money. He still has them sitting on the shelf. There are instances of items that are a "matched set" where I can understand not selling one. I'm involved in Cowboy Action Shooting and have fit several sets of grips to my Colt SAA revolvers. On one brand new set, I hit one of the grip panels too hard on the sanding belt and ruined that side. It didn't surprise me that they wouldn't sell me just the side I had ruined since the odds of someone wanting just the other half would be pretty high. But it seems to me that lower links on a 3-pt. are something that one can assume may need to be replaced. They are exposed to a great deal of stress and use. It just seems unreasonable that you are required to buy the complete set, especially considering the cost. If they only cost $50.00 a pair, I wouldn't feel so bad about having a $25.00 part laying around that I may never have a use for. A $105.00 part stings a little more.
Hoss
   / Don't bend your telescoping links!! #15
Hoss,
I share the exact same sentiment.
   / Don't bend your telescoping links!! #16
But for a $105.you should be able to get what you need...no more. no less.
   / Don't bend your telescoping links!! #17
<font color=blue>But it seems to me that lower links on a 3-pt. are something that one can assume may need to be replaced. They are exposed to a great deal of stress and use.</font color=blue>
This is what I was thinking, too. It'd be interesting to know how many lower links your dealer has sold.
   / Don't bend your telescoping links!! #18
Yep, sounds like my JD dealer as well. I bent a blade hitting a rock with my JD425 MMM. Dealer couldn't sell me just one...had to sell me three. Well, I tried to justify it by saying I'll have three new crisp sharp blades that should make beautiful music by cutting the grass in unison (just like the three tenors). /w3tcompact/icons/wink.gif
   / Don't bend your telescoping links!! #19
I guess my dad should feel lucky... After 40 some years, he broke one of his lower links on his Ford 610 (the ball wore through due to continued one-sided pulling with a sickle-bar mower. 1 arm at the Ford dealer was around $50.00! He couldn't even get it fixed for that!
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2014 Nissan Rogue Select S SUV (A55853)
2014 Nissan Rogue...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52707)
2022 CATERPILLAR...
