Dong Feng 254 PTO disasembly
   / Dong Feng 254 PTO disasembly #1
benjschil
Fredonia, NY
Dong Feng 254
Hello all,
I have a 2005 Dong Feng Bulldog 245 that my father removed the 4 bolts that retain the steel PTO shaft guard onto the rear cast-iron housing at the rear of the tractor. He states that he was having difficulty getting the finish mower drive shaft disconnected, and was trying to get a better view of how to release the quick-connect yoke (this was at the end of mowing season)?anyway after doing so, he hooked up the rear mount snowblower, and I used it, unaware that the bolts were missing from that shield, those same bolts also retain the final PTO shaft support bearing, and a gear inside the outermost removable cast housing. About 5 minutes into snowblowing, the rear section of the PTO slid out of the tractor, leaking trans-hydraulic fluid everywhere etc. I am trying to disassemble and ultimately reassemble the PTO. I have removed the bolts that secure the large PTO assembly housing, and anything else that I can see might be preventing me from removing the entire assembly. I was also foolish enough to remove the countershaft that is directly above the PTO output shaft (thus resulting in a pile of loose needle-roller bearings. I have the seat, transmission cover and upper 3point hitch assembly arm housing removed, in an effort to gain sight and access to the inner shaft. I am able to slide the main rear PTO housing backwards about half an inch, and then it stops solidly. I cannot see what is preventing me from removing that housing, so that I can reassemble all pieces correctly. Do I need to split the tractor at the clutch housing, or is there something simple that I am simply missing? Thanks in advance for any advice.
   / Dong Feng 254 PTO disasembly #2
I can't even work on old Ford PTO shaft assemblies without a shop manual and I consider them relatively simple. I replaced a seal on one a few years ago and I think the whole shaft came out with the plate. A stab in the dark; is the PTO disengaged?
   / Dong Feng 254 PTO disasembly #3
You could jump this down to the Chinese Tractor forum where it will get more views from experienced Chinese tractor users
Thanks. Yes it is disengaged. I too have worked on old Fords, Fergusons etc, and have never run into anything this baffling. Thanks again.
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
1262 (A50490)
1262 (A50490)
2007 International 4300 Dump Truck (A51692)
2007 International...
