Buying Advice Done with hydrostatics
   / Done with hydrostatics #161
and or at less RPM's
Glad pulling a little faster makes you feel better. I guess mowing around trees a little faster, doing loader work a little easier, doing precise movements a lot better counts for nothing?
   / Done with hydrostatics #162
The neighbor has a Allis D17, Ferguson, and a WD. They work great out in the field raking or baling hay but they sure are a pain in tight quarters. My wife could easily move my Boomer in close quarters while I was high in the bucket. That would not happen with a stick shift tractor...NO WAY!
   / Done with hydrostatics #163
I haven't read this whole discussion. I haven't owned personally a hydrostatic rig with a lot of hours on it. I have just a small 28 hp hst tractor. However I did work on logging equipment for half a dozen years. Most of the equipment we were running were hydrostatic. The forwarders we had were 8 wheeled, with 4 half tracks all around. They would carry 25 tons over stumps and mud in extreme conditions. The Harvestor process I used, which cut the trees down, limbed them, and cut them to 8 foot lengths before piling them were hydrostatic, going up and down the sides of the mountains cutting pulp. The skidders they used were also hydrostatic, after using the old 230 jd timberjacks for many years, the new equipment was hydrostatic. They never had an issue with the equipment and they were used in much more extreme conditions then any farm tractor is used. It all seemed to work fine. The harvestors worked 24/7 all year. Never seemed to be an issue with that stuff.
   / Done with hydrostatics #164
Personal satisfaction can come at the expense of efficiency. Once upon a time we all knew we lost a couple mpg by buying an automatic trans in our car, but the
ease of driving was so much better we said fine, lose a little efficiency. Now of course the whole trans efficiency game has flipped around, automatics are usually EPA rated
higher, due to better efficiency than any human control can provide. Commercial equipment changed to "automatic" for a host of good reasons.
We truly have been replaced by robots. And as far as transmissions, I'm ok with that. But for my "fun" car?
Never an automatic. If you've ever tried to get rubber, well ok, a chirp, in second gear with a blue flame six and a three on the tree in the Sixties, you will understand the fun of shifting.
A close friend in high school had a 442 with the Hurst automatic, always wished he had gotten the stick. There's a shoe for every foot.
Take a retired trucker coming out of a RoadRanger trans, well he's likely to want a quad range manual. Or maybe not...maybe he just had enough of shifting after all those years.
I'm a retired senior with very bad arthritis. Hydrostatic is an enabler for me, it allows me to do things I'd never be able to do
for any extended period of time, like loader work. My all manual no reverser MF2615 is great fun to drive, and utterly wears me out after extended hours in the field.
My Kubota is like driving my car, though their standard seat is awful...(hearing this Kubota?)
I also have three different treadle designs to deal with, we all know Kubota and JD do it very differently, well MF's little Iseki has a tiny little reverse pedal behind your foot, frankly
not very ergonomic but maybe the whole thing was designed for a 120 pound guy, not my large frame. So each time I sit down I have to stop and think.
I remember a sign somewhere that said that...
I change the trans oil in my equipment usually at 300 to 500 hours with synthetic if allowed and basically figure it will go forever. Never had a failure, but then I don't pull heavy
loads or work equipment all that hard. Many of you do. Lot of folks pull things with their zero turns. I usually cringe when I see that.
Sometimes the equipment just isn't designed for what you are doing with it.
   / Done with hydrostatics #165
If the mower wasn't to run at vairous speeds there wouldn't be a movable throttle...a on-off choke lever, yes or priming bulb. Small engines are that way on the cheap ones.....has more to do with cost rather than required performance (opinion on that).
Fans are flywheel connected so cooling air is proportional to engine rpm as is heat generated.
HST trannys are fluid controlled variable ratio power transfer mechanisms. Power (work, consumption of energy) out = power in - losses.
On running the pedal to the metal, you are running a 1:1 type gear ratio with no range selector and ranges with ranges...just limiting the variance per range selected. Engine torque is what drives the rear wheels. If you let off the ground speed pedal, you "shift gears" and the engine torque is multiplied like is the case with metallic geared trannys in a lower gear. So for climbing hill, mowing through thick grass, easy on the pedal, keep the pump spooling. Smooth level surface, or short, thin grass, pedal to the metal if you want and lay the ears back.
Gazooks! What a wonderful full-throttle RANT. Wish I could write half as well.
Would stay and chat, but gotta go help my buddy rebuild the carb on his 1970 Chevy PU. I should have never sold him that truck.....
rScotty
my oldest son beat me to it but I also am planning something like this, maybe more along the lines of a diesel rat pickup, my triple carb days being long gone :))))
   / Done with hydrostatics #167
Oh wow! That is a sweet C10!!
git in line!
The "Possum Creek" painted on the door is priceless.
THAT may have been on it when bought, I don't know but I'll find out. The little bugger when he was just a wee lad I would bend down almost to my knees and tap him on the head "how's dad's little son today?" Now around 6 foot 13 and with arms like my WAIST he does exactly the same thing to me :)
Y'oughta see the paint! Painstakingly antiqued and then multi clear-coated. It's a jewel. I'm thinking of setting him up with a few ladies, you know? "Video for truck" sorta deal.
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
Metal Filing Cabinet with Shelves and Drawers (A54816)
Metal Filing...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2018 Kubota U17 (A53317)
2018 Kubota U17...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55315)
LIKE NEW 2023...
