Dominion cast water pump
/ Dominion cast water pump #1
Alberta Girl
Various
Hi, I recently purchased a antique water pump that I would like to mount on my well in the yard... I am in search of the suction chamber (not sure if that's what it is called) the part that is lowered down the hole and draws the water up... If anyone knows where I might find one or an alternative it would be greatly appreciated...
/ Dominion cast water pump #2
Northern tool just sent me an ad for a new reproduction pump. It was cheap enough, you could rob the parts you need. NortherTool.com
Thanks I will try that...
They didn't happen to post the model or stock number did they? When I search it it does not show up..,
I found a plumber that can get the after market parts for me... Cross your fingers it works :)
/ Dominion cast water pump #7
To tell you the truth not at all!!!
The guy said it is a 2" brass cylinder and the tubing and rod are plated ???
Is that size okay or am I gonna have to look like Arnold to get it out of the ground ;-)
Thank you so much for the link !!! I will try to call them as we are looking for a windmill as well ... I just hope they ship way up here !!! Haha
2012 VOLVO VNL64T630 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2012 VOLVO...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
Kubota L3901HST
Kubota L3901HST
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
