Dometic generator
   / Dometic generator #1
sam5570
Veteran Member
south west virginia
new holland tn70
well i have run out of ideals now. i have a 1983 dometic 4000 watt generator, it's in a 1983 motor home i can't find any engine id without taking it out of the motor home witch is a major job. it has a tag says it was built by genrac. i called genrac they couldn't tell me anything i called dometic and they couldn't tell me anything. i need a carb for it. i have checked online with several people and they can't help it's a walbro carb lm6. anyone know who i might contact to even find out what engine it is without taking the generator out. thank's
   / Dometic generator #4
I'm familiar with some of their other RV products, but not their generators. Try the link below for Contact info.
Generators - Dometic
If you can't get parts for the Dometic, personally I'd probably spend the time to track down a Used Onan RV generator to swap in. Good generators, and people that are in the know will pull them before scrapping an RV.
Good luck. Rgds, D.
   / Dometic generator #5
Try googling the carb name/model.
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
WOODS RT48.30 LOT NUMBER 234 (A53084)
WOODS RT48.30 LOT...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2011 DOOSAN ALL TERRAIN FORKLIFT (A52576)
2011 DOOSAN ALL...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
