Dolly for implements
/ Dolly for implements #1
astor
Northwest Lower MI
Kubota Bx2230
Hey TEchman,
I took your advise and built a platform on wheels to move my BX implements around. Once I get the hang of using the hook and chains for picking things up I will really be in business /forums/images/graemlins/laugh.gif
I am attaching a photo of my new platform and my baby /forums/images/graemlins/grin.gif
Thanks for the tip.
Steve
/ Dolly for implements #2
Steve, I too made wheeled platforms for some of my implements, but I added metal brackets or blocks of wood to hold the implement level. This makes it easier to hook them up to the 3pt. Now life is getting better. Kevin
/ Dolly for implements #3
I welded wheels on the bottom of my Ballast Box as well as on the bottom of my sprayer (see pictures in the PHOTOS section of TBN). No need for a separate dolly for those.
For things like blades, a dolly would come in very handy, I haven't gotten around to that yet!
I've also built a low shelf against the back wall of my garage. I can slip a low implement under the shelf and park another implement on top of the shelf (your 3pt has to have enough lift to do this).
/ Dolly for implements #4
Astor:
Here is the one I made. A bit simpler and I only needed it for the snowblower.
paul
/ Dolly for implements #5
I've made several by starting with recycled bed frames. I weld corners so they don't fold, add some reinforcement across the corners and weld 4 swivel casters from Harbor Freight on them. I also added some custom wood and or metal pieces on top to set implements down and keep them in place. One person can take things on and out the 3 point and move anything anywhere with these.
/ Dolly for implements #6
Most of my implements are on dollies made of wood and casters. The dollies are all the right height to roll right up to the 3ph. Having them in the garage on smooth concrete is so easy. When I want to attach or disattach, the cars go out & there's plenty of manuvering room. I did simply bolt casters to the bottom of my carry all. My PHD is bolted to the wall with a chain hoist above it for easy transfer to the tractor. I have an electric hoist suspended from a truss to use in lifting the MMM to remove & sharpen blades, etc.
Somewhere back in the archives there's a long thread with quite a few photos of dollies for BX implements.
/ Dolly for implements #7
Astor,
where is the tooth bar for the FEL. You know not to go out with out your teeth right?
/ Dolly for implements #8
Dan..... it is strange that you should say that about the tooth bar. I purchased one when I purchased my machine and used it all last summer. Then I took it off for the winter and didn't put it back on till today. The only reason that I put it back on was a member sent me a PM asking a question about it. Decided to send him a picture to go with the answer. For what I have been doing this year, I have had no use for it. I do like the fact that it is off & on in minutes.
/ Dolly for implements #9
Junk
How right you are. I consider my tooth bar an implement, just like any other. Mine is off right now also, got some slicing to do on some higher ground and dont want tooth marks.
Point with photo in question is there are NO holes for one either.........and I dont think they stay on to well with c clamps.
/ Dolly for implements #10
I paid about $20 for a furniture dolly at Harbor Freight. It is rated 1000 lb capacity and worked very well for wheeling my 550 lb. box scraper in and out of a shipping container (with some help from 2 come-alongs to lift it).
/ Dolly for implements #13
</font><font color="blue" class="small">( I paid about $20 for a furniture dolly at Harbor Freight. It is rated 1000 lb capacity and worked very well for wheeling my 550 lb. box scraper in and out of a shipping container)</font>
Premade dollies can be inexpensive and an easy way to go. Some implements, though, need a custom design. For my brush cutter, the shape and height had to match the implement. For my rear blade, the body is triangular. There's a groove for the blade, and on the front I have a post with cradle to hold the arm at the perfect height and attitude to dock with the 3ph. I have almost as much fun designing and building dollies as I do driving the tractor. Kind'a gives me excuses to keep buyin' more implements. Tee Hee Hee /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Dolly for implements #14
It'd sure be nice to have a "stock" dolly that would hold most implements, but ....... alas, all my implements have different footprints, weights and so on. So, when I finally built a garage with a level floor, I made a dolly for each (brush cutter, box blade, rake, chipper/shredder), except my FEL, which I just drop onto the garage floor. I used 2"X6" planks, screwed together, and 4 large dolly wheels per implement(tried using smaller ones, with 6 wheels instead of 4, but they are harder to push when loaded). Mounted each implement on the 3pt, brought it into the new garage, lowered the implement until it was about 9" above the cement floor, and then configured the planks underneath the implement, plus any special supports needed (e.g., chipper/shredder will tip forward if there isn't a post under the 3pt attachment), and just cut the wood accordingly. Nice evening in the garage, a few beers, lots of music in the background, and now all implements have a "home". Sure beats my prior 4 years of just dropping stuff on the ground, and dreading the crowbar/hammer/swearing that was sometimes needed to remount an implement.
Ingersoll Rand 185 Air Compressor (A62679)
Ingersoll Rand 185...
John Deere 950 Tractor (A65579)
John Deere 950...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2017 Subaru Forrester (A62613)
2017 Subaru...
