Dog run
/ Dog run #1
kcbarnes
michigan
TC40D,woods M2050 ztr
Next summer I will be building a garage and adding a deck to the back of the house.Under the deck will be a walk out basement that I will do some sort of patio. What I would like to do is fence in a small part of the back yard and walk-out for a dog run for our border collie. I know that any grass in that area is doomed so I would like to put something down to help keep the mud at bay and be good for a dog to be on.I don't know if some sort of stone, gravel or fabric is in order. Any ideas?
Kevin
/ Dog run #2
Depends on the ground. Woodchips work well unless there's a lot of moisture there, in which case they decompose and cover your dog with the dreaded slime of decay. The best setup I ever saw was a breeder who used pea-sized gravel of a significant depth. Easy to spot the poop. The small size and smooth shape of the gravel didn't get stuck in paws. And the once weekly dousing with a bleach solution quickly disappeared.
Pete
www.GatewayToVermont.com
/ Dog run #3
KC,
I used 16" concrete squares sitting on sand with sand between the joints. They had a sale on them and I used about 50-60 of them. The advantage over pouring concrete is you can move it or change if you want to. In two years they haven't moved much at all and still look pretty good.
/ Dog run #4
I am not convinced that any one surface is the all-around best. The trade-offs I usually think about are comfort, sanitation, and security. The relative importance of these items depends on your dog, size of the run, fence construction, etc.
Grass is a wonderful surface for a happy dog, if he will leave it alone. Unfortunately, it holds bacteria and parasite eggs and can be dug out by a persistent digger.
Concrete is great for cleanup (i.e. sanitation), but is not that good to run on (constant pounding on the dogs joints may lead to injury).
Pea gravel is OK for footing, and is not the worst surface for sanitation. However, it can be easily dug out.
I have seen pavers used successfully, but have also seen one run where they collapsed at an edge due to undermining by rodents or erosion.
/ Dog run #5
The kennel where I bought my dogs uses a combination of stone dust in the larger areas and thick, rigid rubber panels in the individual runs. The panels are terribly expensive though.
I'm building a new kennel next summer. I've decided to go with concrete. It's easier to clean; easier to shovel snow in winter; keeps the dogs pads in good condition; and keeps their claws short (I hate trimming black claws). The kennel that they're in now is all stone dust. It's a good surface once it's hard, but if the dogs dig it up before that it's difficult to fill in the holes - they keep re-digging.
/ Dog run #6
Kevin,
One of the best methods of keeping your dog in a confined area is to use a hidden fence. I was skeptical of their effectiveness until a neighbor installed and trained their dog with it.
They work!!
We purchased an Innotek Smart Dog Contain N Train system. It does two things. Contains the dog and has a remote for training. It is somewhat expensive about $300 depending on where you purchase it. We got ours off of the net.
We installed about 1500' of wire around the perimeter of our property. this gives our dog about two acres to enjoy. This way you do not have to have any special place for the animal. It can choose it's "favorite" area and have some room to just be a dog.
We also have a bordie collie. They are fairly easy to train since they are fairly smart and sensitive (did you ever see a dog pout!!). Once they learn about the flags which mark the borders and understand what the shock means in relation to the flags, the dog will stay within the confines of the perimeter.
Terry
/ Dog run #7
I gotta agree with any of the "shock treatment" approaches to containing dogs. I resisted for long time, thinking it would be too cruel of a thing to do to my australian shepherd/border collies (see attached), but when a 6-foot cyclone fence proved to simply be something to climb over or dig under, I bought a fence charger. /w3tcompact/icons/frown.gif
I remember spending a couple of weekends "electrifying" the entire yard, including some 300 feet of chain link fence in preparation for their new confinement. I dreaded the idea of zapping my li'l friends every time they felt like doing what comes natural, but I knew I had to do something.
Now, the irony of the thing was that each dog touched that wire exactly once with a wet little nose, and immediately decided that it was something that was to be avoided at all costs. /w3tcompact/icons/crazy.gif They eventually learned that they could walk right up to it, even lean over it, but they were not willing to go any further than that. From that point on, I could confine them anywhere I wanted by simply laying a piece of the same wire on the ground. Even inside the house, if I wanted them to stay out of the living room for a while, I just laid a piece of wire on the floor at the entrance to that room. I could then spend the rest of the evening watching them sit patiently at that doorway, just waiting for me to take that wire away. /w3tcompact/icons/smile.gif
If I had known it was going to work that way, I could have saved a lot of time and money by just "conditioning" them to the wire and then just playing the bluff. /w3tcompact/icons/wink.gif
/ Dog run #8
We built one out of pressure treated wood, like a real light-duty deck. 2x4 sleepers right on the leveled ground, then 1x6 (not 5/4 decking, a 1x6 measures 3/4" x 5 1/2" and is cheaper) screwed on. After this had been in for a few years, I went back and modified it so it was smaller than the kennel area by 6" on each edge, to offer the dogs a "killing zone", for the mice which had decided it was a good idea to live under there. Now, no more mice since the dogs can wait for them at the edge and kill them. The toads do love this arrangement though, and they are beneficial. I feel the wood is easier on the dogs joints than concrete, since it is an insulator and is not as hard and abrasive. So far this simple arrangement has lasted 14 years and there is not end in sight yet. If you do this, put your boards tite together since they will dry and leave gaps. And use stainless fasteners because I have had to replace a few as they seem to rust off. Do only half the kennel, set the dog house(s) on it, then the other half can be sand. The dog figures this out pretty quickly. Cleanup is easy on sand, even runny ones can be rolled and picked up with a small shovel. To prevent digging out at the fenceline, 6x12x2 patio pavers can be buried on edge 6" into the ground, end-to-end right under the fenceline. I have not had one dig deeper than halfway (and I own a husky). The wood is easy to clean with a hose. For geriatric dogs with bad hips and traction problems, you may wish to add what is called "cow mats", a 1" thick deeply grooved rubber pad of 4' x 6' for about thirty dollars. I use these in high traffic areas around the food and water, and at the doghouse entrance. They are comfortable to lay on, they are black and warm up faster in cool weather, and they rinse easily. Curiously, the dogs will not chew them, even my new Shepard puppy has no interest in biting them.
/ Dog run #9
<font color=blue>dig deeper than halfway (and I own a husky)</font color=blue>
I can attest to this! We've had a husky for just a little over 1 year and boy does he like to dig! He also likes to 'talk'. He's got the smallest bladder of any dog we've owned (he almost didn't live through house training /w3tcompact/icons/wink.gif and he soaks any new visitor to our home). He's the most animated dog we have ever owned. I'd buy another one in a heart beat. /w3tcompact/icons/smile.gif
/ Dog run #10
"buy another in a heartbeat..."
Want mine? Just kidding.
/ Dog run #11
<font color=blue>Want mine?</font color=blue>
I can completely understand. At several points during house training I was ready to ship him off to the SPCA, I didn't care what we paid for him! And I wasn't even home all day with him.
/ Dog run #12
I forgot to add something important about the Smart Dog system. It has an audible beep. Once the dog learns that sound, you have their attention.
Tip, our Border Collie, just becomes a limp towel when he hears that sound. Sounds cruel, but not really. Our dog is single minded and we had to do something to get his attention. It worked. Now that with obedience training, he's become a real joy to have around. Plus, we can let him out all day and really not have to worry about him getting into trouble.
Terry
/ Dog run #13
Terry,
I was watching TV and they showed a similar rig except instead of shocking the dog the transmitter triggered a receiver which pumped out compressed stuff the dog wasn't supposed to like. I think they said it was "Cetronal" (sp). Ever heard of such a thing?
Al
/ Dog run #15
Twinkle Toes,
Nope, but sounds similar in theory.
I don't know about the rest of you but having a trained, well behaved dog is a pleasure. Prior to our Border Collie, I've had two standard collies. Much easier to train in my opinion. A Border Collie takes work. Once trained, they are wonderful. But getting there is like having a couple of toddlers. They want to listen, but something drives them to think for themselves. Just a breed trait, once harnessed and understood, great animals.
An example, I've trained Tip to get his electronic collar and return it to me prior to being let out. It took two sessions. In fact, he's beginning to retrieve his standard collar as well. The next step is to get him to bring it to us to show that he wants to go outside. A little more tricky, but doable.
Terry
<P ID="edit"><FONT SIZE=-1>Edited by TerryinMD on 12/22/01 11:37 AM (server time).</FONT></P>
/ Dog run #16
Terry,
What kind of training methods do you use? Sounds like you have pretty good success!
We're in the process of looking for a dog (probably a puppy from the pound) and want to be sure we will eventually have a well mannered companion! Are there any books you can recommend?
Thanks!
Billboe
/ Dog run #17
billboe,
To be honest, we have taken our dog to obedience classes. Since I commute a hundred miles back and forth to work daily and our youngest daughter was the one who primarily wanted to have a dog, we had to resort to formal training.
First and foremost, understand the breed of dog before jumping in headfirst. It really makes a difference. Each breed has traits that need to be understood. A Bordie Collie is a highly motivated animal, they just love to work and please. Key word is work. Very high energy animal which needs a lot of attention. They are task-oriented and need to be worked. That is one example. See the attached photo of a Red Border Collie in his observing mode. Seems like he's ready to attack, but actually just watching and "counting". Yes, they count.
My youngest daugher had ZERO experience with training or, for that matter, being around dogs. She watched too much Animal Planet Channel and thought that it would be cool to have a Border Collie. I like dogs and thought that it would be a good experience for her. So, she promised to work with the animal, yada, yada, yada..... /w3tcompact/icons/crazy.gif
The Contain and Train system was primary to keep the dog on our property. I hate kenneling dogs in a run or tieing them up. What's the sense of having a dog if you can have them be a dog? Anyway.... This system has given the dog a couple of acres to run a play and we don't have to worry about him taking off. It has also helped in having him respond to commands. Tip is a very focused dog and loves to be outside. Once he made his mind up to be outside, he was going to stary there!! The collar came in handy to change his behavior. Since he understood what the beep meant with the containment system (beep once - no shock), all we had to do is utter the command "Come", if he did not respond, I'd beep the collar and he would come to us for safety. Two sessions and now no problem. There is a little more in the next paragraph.
We joined the local Kennel Club. Luckily, it is only a few miles from our house. They have a women who is an excellent trainer. The lessons were to teach my daughter and the dog (the daughter needed more work /w3tcompact/icons/wink.gif). Since joining the club and taking advantage of the lessons, Tip is becoming more manageable and the daughter has more confidence. I also have learned by observing how the trainer works with the people and the dogs. It is amazing to see how the dogs behave with the trainer and then with their owners. Uh-huh, dogs are REAL dumb - right!! They know how to manipulate us and get what they want. Cost - $85 for the first eight weeks, $50 for next eight weeks, $35 for the next session. Yes, the cost goes down (at least for us). The trainers reasoning is that the further training you receive takes less time and effort on her part and that you want to be there. Very interesting concept!!
To sum it up, if you haven't had the opportunity to work with dogs for a while or at all, it would probably be good for you and the dog to go to classes. It gives you the understanding of how to work with the dog and confidence to command them. The dog will learn the commands through the training and reinforcement by the owner. Again, once trained, dogs are a joy to have around.
Oh yes, trainers. Ask around your area. Talk to some local rescue groups. Two reasons, they'll be able to tell you about trainers and you should be able to get a nice dog.
Hope this helps.
Terry
<P ID="edit"><FONT SIZE=-1>Edited by TerryinMD on 12/24/01 08:12 AM (server time).</FONT></P>
/ Dog run #18
Hello Terry,
Yes, I've read a bit about border collies... Like you said, they <font color=yellow>NEED</font color=yellow> a job. The photo you have of Tip (I assume that is Tip) is just what you think of when you think of a border collie!
Rescues are a good suggestion... We're interested in giving a dog that "needs" a home a home, so, we've haven't been thinking much about "pure breeds". Plus, while we want to do a good deed, we're not angles... We want to make sure we get a dog that we can live with.
Anyway, thanks for the information... We'll probably to some reading on our own as well as tap the local training talent.
Billboe
/ Dog run #19
Billboe,
Yes, that is Tip. In that picture, he's waiting for one of us to throw the frisbee. If you didn't understand a Border Collie, it would look like a threatening stance. The sheep don't know that though.... /w3tcompact/icons/wink.gif Hmmmm, neither does the frisbee. /w3tcompact/icons/laugh.gif
Local animal shelter or rescue organization, either way you're doing the right thing. Any animal you get is somewhat of a chance, you try to "feel" out their tempermant and character. Shelter animals tend to be not wanted. Rescue animals tend to be abused!! With that in mind, you need to spend a little more time with animals from a rescue organization. Typically, the people running the rescue will try to help you work with the animal.
We have a few people in our neighborhood who have gotten animals from rescue shelters and have had good success. Took them some time to work with the animals, but all in all, things worked out good for the dog and the new owners. It's a labor of love.
Happy Holidays to you and good luck.
Terry
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2000 (INOPERABLE) KENWORTH T800 (A67714)
2000 (INOPERABLE)...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2001 John Deere 5310 64HP 4WD Loader Utility Tractor (A66734)
2001 John Deere...
