Does your PTO Work Intermittently on CC 2160?
   / Does your PTO Work Intermittently on CC 2160? #1
Altair 4
Cub Cadet 2160
File this a FYI kind of thread.
I have had an occasional problem where the PTO on my 2160 with a 48" deck would intermittently not work. I finally had enough time to look at this more carefully, since the PTO is relatively new with probably less than 40 hours on it.
I discovered that the electrical connector between the tractor's wiring harness and the PTO wire was deformed. I don't know if it was from engine heat or from heat from the electrical connector itself. The red wire connection was only making marginal contact as a result. I tried to realign the connection but ultimately ended up cutting the connector out completely and replacing it with crimped spade connectors from Radio Shack. Everything works like a dream again!
   / Does your PTO Work Intermittently on CC 2160? #2
I seem to be having the same problem with my 2550. I know the wires to the lights are melted, but I don't think the PTO wires are damaged, though. I'll have to take a look because my PTO won't engage anymore.
   / Does your PTO Work Intermittently on CC 2160? #3
There are a few interlocks on your PTO that could fail as well as a possibly toasted wire.. Just a FYI..
ASSET DESCRIPTIONS & CONDITION (A57880)
ASSET DESCRIPTIONS...
2018 Ford F-150 (A55973)
2018 Ford F-150...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
Informational Lot - Shipping (A55315)
Informational Lot...
Sterling 9500 (A55315)
