Does welding gas go bad?
/ Does welding gas go bad? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I realized that I am no where near burning through any of my tanks of gas (Acetlynene and propane, as well as my CO2 and O). and when I say getthing through them, meaning they are now creaping up on 4 years old, with this pace meaning another 4 years before refill.
/ Does welding gas go bad? #2
I don't think it goes bad, but leakage is always a possibility.
/ Does welding gas go bad? #4
I have never heard of any of the welding gasses deteriorating. I have heard of them leaking though.:)
/ Does welding gas go bad? #5
The problem is not the gas... it's the container/cylinder and for most of us there should never be a problem.
I've had cylinders come through from the 1920's.... even a couple with **** swastikas stamped on the neck... who knows what stories they could tell.
Medical Oxygen, Nitrous Oxide and Nitrogen no longer come with an out date.
/ Does welding gas go bad? #6
I don't think any welding gases will go bad but I have heard tales of the 75/25 blends (and other blends) that if allowed to set for long periods of time MIGHT separate the blends which I consider that a possibility when you consider that some gases are heavier than others and could segregate over time.
I do know that many places will lay a bottle on its side and roll it over and over to "remix" the gasses prior to putting on a fresh tank. I DONT know if this is just an old wive's tale or not.
/ Does welding gas go bad? #7
I'm no professional or constant user like Shield Arc, but I'll go thru 2 sets of bottles on the torch and MIG a year. I worry WAYYYYYY more about my forgetfulness and leaving the bottles on than the product going bad..... :)
/ Does welding gas go bad? #8
I've filled my oxy/acetylene tanks exactly 3 times in the last 25 years. So, on average, 8 years and still goes WOOF! when I light it. Your mileage may vary. :)
/ Does welding gas go bad? #9
You must have extremely large bottles!!!!!
/ Does welding gas go bad? #10
That's a personal question... ;)
Nope. Just not much to do anymore. I only use it to rough cut some steel here and there, and heating things once in a while. Last kid leaves for college in 8 months. Things will pick up again. ;)
2012 HEIL (A60736)
2012 HEIL (A60736)
2017 Ford Taurus Sedan (A59231)
2017 Ford Taurus...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
