Price Check Does this sound like a normal start up?
   / Does this sound like a normal start up? #1
lristau 01
Does anyone else have a ct122? Is this what it sounds like when it starts up first time if the day. After that it starts easy.
Exhaust - YouTube
   / Does this sound like a normal start up? #2
Sounds normal to me when its cold. (I see snow in the background)
It was in a heated garage. Around 17-18 degrees celsius. Thought it either is losing prime or these tractors just start a bit rough
   / Does this sound like a normal start up? #5
"IF" it was around 60F and you your glow plugs working then it did not sound normal to me.
   / Does this sound like a normal start up? #6
Agree: My 225 will start like that @ 40-50f if I don't wait for the pre-heat. If pre-heat dash light is on and you are waiting for light to go out before cranking, check resistance if glow plugs.
Within seconds of starting to crank there is smoke present = is getting fuel.
   / Does this sound like a normal start up? #7
Your not giving it enough throttle.. bring it OFF OF idle just a tad.. it'll make all the difference in the world.
I think, if u read the owners manual, it says to..
   / Does this sound like a normal start up? #8
It's a diesel. It's cold. I let my CT235 idle for half a minute to get the oil flowing before idling up a couple hundred RPM's. Synthetic oil, mind you. The pour point is - 50. Molasses oil will take longer to reach the top of the head. Consider a block heater?
It's in a heated garage here. I think I will try giving just a little more throttle then idle when I get home tomorrow and let you guys know how it goes.
Thanks for all the ideas and opinions. Much appreciated
   / Does this sound like a normal start up? #10
No comments on your glow plugs? You sure they are working? These engines need those on first crank of the day even though garaged. Without using them they crank just like your video.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
