Price Check Does this sound like a normal start up?
   / Does this sound like a normal start up? #1
lristau 01
Does anyone else have a ct122? Is this what it sounds like when it starts up first time if the day. After that it starts easy.
Exhaust - YouTube
   / Does this sound like a normal start up? #2
Sounds normal to me when its cold. (I see snow in the background)
It was in a heated garage. Around 17-18 degrees celsius. Thought it either is losing prime or these tractors just start a bit rough
   / Does this sound like a normal start up? #5
"IF" it was around 60F and you your glow plugs working then it did not sound normal to me.
   / Does this sound like a normal start up? #6
Agree: My 225 will start like that @ 40-50f if I don't wait for the pre-heat. If pre-heat dash light is on and you are waiting for light to go out before cranking, check resistance if glow plugs.
Within seconds of starting to crank there is smoke present = is getting fuel.
   / Does this sound like a normal start up? #7
Your not giving it enough throttle.. bring it OFF OF idle just a tad.. it'll make all the difference in the world.
I think, if u read the owners manual, it says to..
   / Does this sound like a normal start up? #8
It's a diesel. It's cold. I let my CT235 idle for half a minute to get the oil flowing before idling up a couple hundred RPM's. Synthetic oil, mind you. The pour point is - 50. Molasses oil will take longer to reach the top of the head. Consider a block heater?
It's in a heated garage here. I think I will try giving just a little more throttle then idle when I get home tomorrow and let you guys know how it goes.
Thanks for all the ideas and opinions. Much appreciated
   / Does this sound like a normal start up? #10
No comments on your glow plugs? You sure they are working? These engines need those on first crank of the day even though garaged. Without using them they crank just like your video.
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
Non running toro mower (A48082)
Non running toro...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
