3-Point Hitch Does the s650g three point hitch have down pressure?
   / Does the s650g three point hitch have down pressure? #1
bobpsr
Hubb, Taxachusetts
Satoh
Regardless of the adjusting lever position (lock/till/plow), the hitch will not push down on the grader blade. It just stops when it hits the ground.
Any info would be appreciated.
   / Does the s650g three point hitch have down pressure? #2
No tractor Three Point Hitch has down pressure.
If Three Point Hitch had down pressure, down pressure would merely raise rear wheels off the ground.
All non-PTO implements are dependent on implement weight for ground contact function on the Three Point Hitch.
Keep auditing this site and before long you will be a tractor genius.
   / Does the s650g three point hitch have down pressure? #3
Jeff's right, no tractors have down pressure on the 3 point. They rely on weight of the implement and I would say, even more so on the angle of your implement in many cases. In the case of a back blade, which I think is what you're talking about, lengthen the top link of the 3 point. That will tilt the blade back and make it "bite" into the material. Plows work the same way, it takes proper setup to achieve the "suck" into the soil.
Good luck. Let us know if you have better results.
   / Does the s650g three point hitch have down pressure? #4
Incorrect, Belarus tractors have down pressure on their 3 point.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2000  INTERNATIONAL 3800 MID SIZE SCHOOL BUS (A54607)
2000...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
