Does the Kubota L4500 DT have a hydraulic transmission?
   / Does the Kubota L4500 DT have a hydraulic transmission? #1
Old Swampy
New London, NH
Ford Ranger
   / Does the Kubota L4500 DT have a hydraulic transmission? #2
Welcome to TBN ! Are you reffering to the old M4500 DT ? If so no the old M4500 DT had 16 F/gears and 4 R. I also believe DT stands for direct transmission, gear not hydro.
Boone
   / Does the Kubota L4500 DT have a hydraulic transmission? #3
DT stands for 'Dual Traction, but this designations is used on models with gear drive.
There is no L4500 as far as I know?
"Does the Kubota L4500DT have a hydraulic transmission?"
Thanks, Boone. Yes I got mixed up. It is the M4500DT that I am interested in. 'Looked at a lot of tractor ads today. 'Trying to help out my son.
   / Does the Kubota L4500 DT have a hydraulic transmission? #5
The M4500DT, will be gear drive, but may have a shuttle shift. Our old L3750DT has a hydraulic shuttle shift that lets you change direction without clutching, but it's still a manual trans.
The Hydro models will have HST instead of DT after the model #.
2012 Ford F-550 4x4 Chipper Truck (A52377)
2012 Ford F-550...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A54757)
UNUSED RAYTREE...
