Does running mig/shielding gas penetrate deeper than running flux core?
   / Does running mig/shielding gas penetrate deeper than running flux core? #11
about the inverter stick welders, I have a longevity stickweld 250, and it is very good. I havnt used it a whole lot yet, but so far I highly recomend it. The switch from an ac tombstone to that made me 2x better of a welder.
   / Does running mig/shielding gas penetrate deeper than running flux core? #12
Are these the only two brands of invertor welders on the market? I would like to do a little price shopping before I purchase.
Don't forget Everlast. I have one and I'm happy with it.
   / Does running mig/shielding gas penetrate deeper than running flux core? #13
how many amps does a 220v Arc or Mig generally draw from the panel? Right now my service to the panel to the garage is only 50 amp. I still have plenty of breaker space and the garage has flourescent lights so as long as I am not running any other heavy draw items i would think I could get away with a maximum of a 220 v 40 amp draw. Is this enough to run an old lincoln "grandfather clock" arc or a 125 amp mig?
Thanks for clearing up the mig/flux issue for me. I always had mixed feelings towards flux but it sounds like I was asking more from my welder than it was capable of doing hence the weak welds and lack of penetration.
I run my 255 lincoln mig off of a 40 amp circuit with no problem. If you were running a stick machine with baseball size rod you would have problems. I had a 40 amp circuit on my big Miller stick machine and it would trip the breaker if I was running high amps 180+ for long periods of time. Jumped to a 60 amp and no more problems. I doubt you will be burning 1/2" and 3/4" plate steel together. I would love to get my hands on another of the red clock style welders you are talking about! Where are you located in Michigan? CJ
Ammco Brake Machine (A55758)
Ammco Brake...
2016 BOBCAT E45 EXCAVATOR (A52706)
2016 BOBCAT E45...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
