Does gas really go bad?
   / Does gas really go bad? #71
I'm sure lots of problems brewing...
The fleet has been totally neglected since 2015 due to health issues with Mom.
Car tabs make it easy to track with some going back as far as 2012.
Batteries, brakes, fluids and fuel suffer and tires too.
I really should have been diligent putting vehicles on blocks but the hiatus was not planned...
I regularly drove the classics to work when I had 9-6 hours but 4 am is just to early to drive the 1913 Speedster or Corvette.
With regret it may eventually come to individually get a car road ready to sell.
Gasoline really has never been a problem prior to ethanol...
I'm guessing 75+ engines including tractors and gas power tools.
Of course I could do nothing and it could make for an interesting barn find someday.
   / Does gas really go bad? #72
I guess that I've been lucky, we've only had it since around 2008. I bought a new Echo chainsaw that year, and the warranty clearly stated that it was voided if I ran gas with ethanol in it.
Now that you mention it, I don't recall E-gas much before the mid-00s. To be sure, many small engine manufacturers dragged their feet about making their products E10 compatible.
Curiously, what did petroleum companies put in gas in the early 00s for an oxygenate, I believe MTBE was banned around '02.
Older engines also had carburetors that metered poorly and were jetted rich. One reason why 15 mpg was considered good for an American car in the '60s. Be around running old restored muscle cars and you can smell the raw gas in the exhaust.
Not just muscle cars. I've got a mid-60s Mopar with a slant 6 and you can smell the gas in the exhaust on it too.
   / Does gas really go bad? #73
We have a 2013 Impala with GDI. We never had any concerns with carbon deposits on the backs of the valves. I never saw any performance decrease in it over the 135,000 miles... before the engine failed! :laughing: Something failed in the VVT system. Cam sequencer(s), solenoids, camshafts themselves. We're not sure. The mechanic never dug into it farther than finding huge amounts of metal shavings in the screens on the solenoids. Had to get a junkyard replacement. I've seen the videos of the carbon deposits, and it makes a lot of sense that since no fuel ever touches the backs of the valve, they never get washed. But it's just air on the back of the intake valves, isn't it? Where would the carbon come from? There's no fuel there.
Crankcase ventilation system dumping oily air into the intake?
Aaron Z
   / Does gas really go bad? #74
Gasoline fuels are a time and temp sensitive commodity and are not made for long term storage. They run down pipelines without oxygen until they reach our tanks or cans. Oxygen cross links with it and it changes into something our engines and fuel systems do not like. Heat makes this process happen faster, same as most chemical reactions. All our temporary use engine fuels here has some Seafoam mixed in them to keep this process from happening. Seafoam is much cheaper than cleaning a fuel sytem out.
I used to work in a marine where cleaning out bad fuel was 70% of our work. Note how I didn't mention alcohol. Long live seafoam!
SF is Naptha, Alcohol, and light Mineral Oil, per the MSDS. The small amount of alcohol is there to absorb small amounts of moisture that may occur in your tank as a result of condensation. It is in every tank of my small engines both 2 and 4 strokers. My 2 stroke outboard had an oz per every gallon I put in the tank. It has proven itself to me time and time again. On a couple of occasions, I had old engines that hadn't been run for years...tanks run dry prior to storage. Put in new fuel with adequate supply of SF and in 10min. or so, running like new. Road vehicle gets it off and on being frequently used or something else to ensure the injectors get adequate cleaning.
   / Does gas really go bad? #75
Something I don’t understand, or most likely I’m fundamentally wrong and someone can explain:
If dry gas is basically alcohol that attaches to water so that the water can pass through motor and be burnt off and engine can still run, how come ethanol gas is more susceptible to getting water contaminated fuel?
   / Does gas really go bad? #76
Something I don稚 understand, or most likely I知 fundamentally wrong and someone can explain:
Why do you say that dry gasoline, is the same thing as alcohol?? Alcohol and water like each other. If you put a bottle of 70% in your cabinet. Check it again in a few years and it might then be 50%. Those two chemicals really do attract each other.
   / Does gas really go bad? #77
Because a "gas drier" like the Methanol that comes in the yellow / blue plastic bottle are something you add to your fuel tank because of the condensate formed on the walls of the tank because you were not smart enough to keep you tank full of fuel. And this condensate has slid down below the fuel and formed water pockets that may have frozen and clogged up the fuel inlet. This is different than having the ethanol in your fuel acting as a sponge mixing with the water in the air all of the time and causing a phase separation in the fuel where the alcohol is no longer properly mixed with the fuel. This mixture can cause carburetor parts and some rubber parts (if not designed to resist this damage) to be damaged.
So one is a "rescue" package and the other is a detrimental additive that is working all of the time to suck in water (hydroscopic) to your fuel supply. Of course the oxygenation factor that the alcohol provides is necessary because we no longer use the deadly lead compounds for that function. So it is kind of a double edged sword, we need it in our fuel and and our automobile engines are made to use it and it doesn't seem to cause harm there. The problems come in on the simple small engines of our power tools. Of course a lot of these are rapidly going to electric battery power and battery technology is improving at a rapid pace anyway.
   / Does gas really go bad? #78
Fuel Injected and Non-Vented fuel tanks don't seem to have issues as vented fuel systems.
   / Does gas really go bad? #79
When's the last time you had a fuel line freeze using E10 gasoline?
   / Does gas really go bad? #80
Think it can because there are a lot more chemicals in it that can chemically react, given time. Stuff even tastes and smells way different from the old, fresh gas we used to have. Change came when they took the lead out and had to leave or add back some chemicals in there for octane improvement. That was a LOONG time ago, before many of you were born.
Ralph
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
2019 Dodge Journey SUV (A50324)
2019 Dodge Journey...
