Does engine need rebuilding, Yanmar 1500
   / Does engine need rebuilding, Yanmar 1500 #1
swmillbrook
Deatsville, Al.
Lots of Yanmars
Yanmar 1500 was on a hill, nose pointed downward, while operating a posthole digger in idle position. Engine got very hot. It will still run but makes a different noise and not as much power as before. Haven't checked for metal flakes in oil yet. If none are present, is there something else to check before diagnosing an engine rebuild?
   / Does engine need rebuilding, Yanmar 1500 #2
If anything i think you may have blown a head gasket? How much oil is in the tractor? The hill should not of mattered unless you were really low on oil, these tractors dont have a sump its just a flat plate. Whats the oil level now, did you have to refill after say 3 qts? Start tractor and look in the radiator with the cap off and see if you see bubbles in thier indicating a blown head, or oil in there or water or coolant in your oil, which indicates a blown head.
Dont say for sure your bearings are shot.
   / Does engine need rebuilding, Yanmar 1500 #3
Does it have a knock? Is exhaust smoke different than before? Are you thinking slope maybe caused oil pressure loss?
   / Does engine need rebuilding, Yanmar 1500 #4
Not sure this suggestion would help:cool: but what was the fuel level while sitting on a hill? sorry! I always try ruling out the simplest of things and then move on to the more complex things,
   / Does engine need rebuilding, Yanmar 1500 #5
If it does not have a water pump and the front end was pointed down could that not impact thermal coolant flow?
   / Does engine need rebuilding, Yanmar 1500 #6
fwtw My engine has the oil pickup at the front of the engine so if his does also that wouldn't be a concern running low on oil because its tilted. Probably a radiator issue of some kind plugged with seeds or tubes inside plugged or fan belt slipping. There is always the chance it had issues before and now they are just bigger. my .002
   / Does engine need rebuilding, Yanmar 1500 #7
Maybe! if perhaps the catch bottle was leaking and loosing enough coolant, would be certain to run hot, But you have made a good point, It would be difficult for this type of cooling system to force coolant into area's of the engine if not enough pressure pushing it, I would think if the coolant level became low enough there could be some area's on the upper side of the one cylinder wall while in an angle not receiving adequate coolant,
When reading back I see the OP stated was in Idle when running hot, I've noted my 1700 will run warmer at idle than at a higher RPM, could had something to do with it, Just like cars setting idle with the A/C on will run a bit warmer, Got to get air through the radiator in order to keep the water temp down,
1988 John Deere 4250 (A50120)
1988 John Deere...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Howse 10' 3pt Rotary Mower (A50774)
Howse 10' 3pt...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
V8 Mercruiser Boat Motor (A50121)
V8 Mercruiser Boat...
