Does Branson Offer Auto Bucket Leveling ? How Important Is It ?
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #1
bigcut
SC PA
Garden Tractor
Hi All,
Does Branson offer an auto self-leveing for their Bucket ? Does it come std. or offered as an option, or maybe not offered at all ?
Opinions on the importance of it ??
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #2
Mechanicaly self leveling loaders are available on Australian, UK, and Europian market Bransons. I don't know if they're available in the US. Dave's Tractors and other US Branson dealers should know the answer to this question.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #3
The last I knew in this country only the 8050 had the self leveling, in Europe and Australia it looks like most of them do.
I like it most of the time, occasionally I'd like to get more roll back then the self leveler allows.
It is not the most common in this country, when you find it it's almost always an option or upgraded loader.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #4
My 8050 Branson has a self leveling loader. Love it.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #6
Branson is coming out with an option of self leveling loaders. All I can tell you. Will be available next year. I for one do not like self leveling,. I feel I don't have control of the loader and I want control of it at all times.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #7
I can't imagine how this would work. Cutting edge level to the ground? Or upwards with the front edge level to the back edge? And level to the ground would only work on level ground which I have very little of. If you get on a slope, does the level change? Would YOU want your load shifting without you doing it?
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #8
A mechanical self leveling loader has a linkage built into the frame work,
what it does is keep the bucket at what ever level or curl you set it at as you raise and lower the loader.
As you can see in this picture there is a mount above the rear loader arm pivot that runs up to the triangular plate that changes angle as the loader raises and lowers with the bucket curl cylinder attached to the triangular plate.
You can still curl or uncurl your bucket while raising or lowering your loader if you desire to, but if you just raise and lower the main arms the bucket will maintain its curl as you have it set.
In this picture I have the blade attached instead of the bucket but the blade will maintain it's angle as I raise or lower it.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #9
I bought the BL30, non-self leveling with my 6530 as it was installed on the tractor. In the manuals package the dealer gave was not a BL30 but another Branson 30 series loader and it had the additional pivots and rams on top of the lift arms indicating that it contained the self leveling function. So at least in the 30 series tractors they do make one.
   / Does Branson Offer Auto Bucket Leveling ? How Important Is It ? #10
Can you expound on why you don't like them a little more? Seems to me that it would be better under all circumstances. but I could be missing something.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
UNUSED FUTURE HYD HEDGE TRIMMER (A51248)
UNUSED FUTURE HYD...
1263 (A50490)
1263 (A50490)
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
