Does Anyone Still Make the FEL SSQA-to-3PT Adapters?
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #12
They work great being able to lift attachments like a rotary cutter so you can access the underside.
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #13
Looks like the lower arm connectors are adjustable side to side. Do they lock in place then?
Once you slide them onto the pins of your attachment, just put your lynch pins in
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #14
Mine from ( Heavy Duty Skidsteer To 3 point Implement ) has some extra rollback built in:
And easy to lock the lower arm connectors from sliding sideways:
Store it on a furniture dolly:
All, but one implement already has the bushings attached for the quick attach that are slid over the pin and held on by a roll-pin. The types of adapter with assumes you can slide the fittings over the pins won't work in my case as the bushing ends won't allow it. I wouldn't want to trade up the ability to use the quick attach on the 3 point for this.
The Bobcat one seems nice, but I can't seem to find a price. It looks really nice so I suspect $$$.
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #17
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #18
I built one that closely resembles LouNY's unit in post #10, only with a Cat 1 hitch.
It was originally built it for my bobcat so I could use a 3 point York rake.
Other than having to rake in reverse it worked fairly well.
I no longer have the bobcat, but I still use the rake on the front of the tractor to reach into drainage ditches and clean out debris.
It also worked pretty well at yanking out wild rose bushes along the bank of a creek.
It's handy for moving 3 pt. implements around, especially my friends post driver.
Take a look at;
#70 3Pt Hitch | MS Attachments
They no longer post prices online but I've bought several attachments from them and they were very reasonable.
Might have to try to make one like LouNy and maybe take the trick of adding some extra rollback into it. How many inches are we talking should the bottom extend away from the SSQA plate? 8"? I'll have to surf FB/craigs and try to find a reasonable pre-made ssqa plate. 3/8" good enough for this application?
   / Does Anyone Still Make the FEL SSQA-to-3PT Adapters? #20
My adapter has the 2 side ssqa plates which allows a person to see through it. Those are 3/8" thick. I found out that many of the cheaper ones designed like this had over sized holes for the 3pt pins while this one had tighter cat1 pin sizes. The Minnesota company does not sell these anymore. I added chain hooks to it and also added a 2" receiver to it. (not in picture)
12ft x 8ft Military Flat Bed (A57453)
12ft x 8ft...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2014 Kenworth T370 Single Axle Dump Truck, VIN # 2NKHHM7X6EM419999 (A57453)
2014 Kenworth T370...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
HEAVY DUTY TRANSMISSION JACK (A58214)
HEAVY DUTY...
