Does anyone know what these valves are?
   / Does anyone know what these valves are? #1
Steve OO
Hillsboro , mo
None
It's Monarch Hydraulics 12volt pump with 2 directional manually operated valves. Thanks for any information Steve
   / Does anyone know what these valves are? #2
Those are old 12vdc pumps made for plow units
The rotary valves have small microswitches under the plastic cover to activate the solenoid to turn the pump motor on mometarily when lever is activated
One valve is 4-way for the power angle cyls .........and the other (with one single port) is 3-way for raising and lowering a single acting lift piston
Thanks I was hoping that is what it was now I can start making a snow plow
   / Does anyone know what these valves are? #4
IIRC the switch on the valve is wired to the solenoid to the ground side......the positive side of the solenoid is hard wired to the battery
then the valve switch just completes the ground to turn on the solenoid
   / Does anyone know what these valves are? #5
Does one valve have one port .....and the other two..??
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
